lis_user1
How do I probe all signals in a vivado simulation?
In ncsim I am able to probe all the signals during a simulation without adding to waveforms.
How do I do the same in Vivado and Modelsim?
dprasad
Once simulation is launched do following on TCL console
1> restart -- This is to bring the simulation at time 0
2> log_wave -r *  -- This will log(probe) all signals but won't add in waveform
--dhiRAj
vijayak
Hi @lis_user1
Set debug level to all as in the screenshot attached.
Thanks,Vijay
vijayak
Hi @lis_user1
Did my previous post answered your query?
Thanks,Vijay
dprasad
--dhiRAj
lis_user1
Thank you.
I did both your answer and dprasad's answer.
Now it works.
Thank you both.
lis_user1
A quick question,
Is tcl commands used in model-sim compatible with the Vivado simulator?
My company uses both, reuseability is nice.
dprasad
No, it's can't be due to policy.
lis_user1
I see. I realize I was unable to add a verilog event into the vivado waveform, am I right?
How do I add a event to waveform?
srimaye
Vivado does not support tracing of events in verilog. You can refer pg 43 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_1/ug900-vivado-logic-simulation.pdf
Srimayee
vijayak
Hi @lis_user1
Please create a new thread for the neq queries. This way it is easier to track.
Thanks,Vijay
lis_user1
Ok.
tflekan_ddc
Hi dprasad,
I'm responding to this message late but I have a related question: how do set up Vivado to probe none of the signals?  I have a regressions simulation where I only care about the text output and a pass or fail.  My intent is to run the simulation as quickly as possible and would like to disable all logging and debug features.  Can you help with this?
Ted
