fradaric
I2C protocol
Hei friends,
I made a verilog code for I2C, and I need to test my design. I made a testbench and while testing, the "inout" pin can't be assign any values. Since it is I2C protocol after the start and address bits there will be a acknoledge 'high" bit from slave(assume mine is the master I2C) , so how can I test my design by providing the ack in testbench. Or let me know is there any other ways to do this......
regards,
Fradaric
fradaric@gmail.com
Joe
gszakacs
Professor
Professor
There are two ways to test this.  When you say that the "inout" pin can't be assigned,
you're only partly right.  A continuous assignment to a hard value like 0 or 1 will override
the output of your unit under test.  Therefore the inout SDA pin needs to be assigned
a Z by the testbench when it isn't driven by the testbench.  For example if your testbench
includes a signal ACK that indicates when to drive the SDA line low by the testbench,
you can have:
assign SDA = ACK ? 1'b0 : 1'bZ;
Another way to test your master code is to instantiate an I2C slave in the testbench
and just wire the SDA and SCL lines between the two.  In addition you should
add pullups to the testbench:
pullup (SDA);
pullup (SCL);
This makes sure that the unit under test and I2C slave both read a 1 on the lines
when they are not actively driven low.
-- Gabor
See also this thread:
http://forums.xilinx.com/t5/Spartan-Family-FPGAs/VHDL-I2C-Slave-core/td-p/2831
-- Gabor
fradaric
Dear, I really don't understand. In my design I made one reg sda_int and inout pin sda.
for passing values to slave I use sda_int and then 'assign sda    =sda_int;'
to get values from slave I am using sda. And I am still confused how to test this device. In my top module I have a reg named 'ack' it becomes high when slave acknowledges, but in test bench how can I do this??? ie testbench parameters are
I2C uut (
        .sda(sda),
        .scl(scl),
        .out(out),
        .clk(clk)
Joe
avrumw
Guide
Guide
In the I2C protocol, all drivers are "open drain". What this means is that drivers can only pull the signals low - they can never pull them high. There is also a resistor on the "board" which will pull the signals high when there is no active driver pulling them low.
In the simulation world, this means that (first), you need a pullup on SDA and SCL. As Gabor suggested, you can use the Verilog "pullup" primitive.
The clock is normally managed by the master - it pulls the clock low and then releases it more or less periodically during an operation. A slave is allowed to also pull the clock low (when it is already low) to extend a bit cycle - this is called "clock stretching" and only slow slaves do it. Lets assume for the moment that your testbench slave won't do this...
Now comes the SDA line. The master will drive it low and release it appropriately for the start condition as well the first data bits. At the end of the the first byte, it is time for the slave to ACK the access, or not. To do this, it will pull the SDA signal low, and release it after the ACK is compelete (based on the clock, which is controlled by the master).
Like the master, the slave is only allowed to pull signals low, and release them (allowing the pullupto pull them high). In simulation, this is done using a reg, but only assigning one of two values - either 1'b0 to pull the signal low, or 1'bz to allow it to float, which will cause the pullup to pull it up (assuming the other driver is not also driving it low).
So in your case, your slave can sample sda when it is supposed to be receiving data as long as sda_int is set to 1'bz. During the ACK time, if you want to ACK the byte, then set sda_int to 1'b0. Once the ACK is complete, return it to 1'bz.
Avrum
fradaric
Heyy..
In my design the delay time for I2C is not included.. How can I do that, the edges of SDA also appear to coincide with the clock edges of SCL,  in verilog language I am assiging slave/pointer address to sda by a always @(posedge scl) , thats y this problem occurs...... but I don't know how to solve this, ie how to make transitions 100ns prior to the clock edge (my slave device needs 100 ns setup time).
Joe
fradaric
I have attached the timing digram below, which shows the problem that I asked before. i.e my scl and sda transitions occures at the same time. How can I add the setup time(100ns).  I was doing the slave address assignments , pointer addressins with a always @(posedge scl).
`timescale 1ns / 1ps
// Fradaric Joseph
// Indian Institute of Technology Guwahati
// Ph: 09401015142
module I2C(
	inout sda,
	output scl,
	output [15:0] temperature_out,
	input clk,
	output [2:0] ack_out,
	output [1:0] ack_count1,
	input reset
parameter clock_div=500; //  I2C clock 50MHz/(500)=100KHz
//---------------------------I2C State Machine Variables----------------------
parameter Rxidle	=0;
parameter Rxstart	=1;
parameter RxPointeraddr	=2;
parameter Rxstart1=3;
parameter Rxdata	=4;
parameter Rxstop	=5;
reg chk=0;
reg [2:0] ack;
reg [1:0] ack_count=0;
//reg poiter2=0;
//reg ack2=0;
//reg ack3=0;
reg I2Cclk			=1;  // I2C clock
reg [8:0] clkclk=clock_div; // in order to divide 50MHz clock
reg sda_int			=1; // making SDA high in initial state
reg [15:0] outreg	=0;
reg [3:0] I2C_counter=0;  // for giving the pointer address (000000-00(P1P0))
reg [3:0] bitaddrs7=4'b0001; // initializing via giving slave address(1001000-0(R/W))
reg [3:0] Rxcount=0;
reg [3:0] slaveaddrs=0; //receiving data from TMP 100
	reg [2:0] state 	=Rxidle ; // For State machine starting
	assign scl	=I2Cclk;// Generated Clock for I2C
	assign  temperature_out = outreg;  // output from TMP 100
	assign sda	=sda_int; // Using SDA pin
	assign ack_out=ack;
	assign ack_count1=ack_count;
always @ (posedge clk) /// --------------------- scl generation-----------------
begin
if(!chk)
	begin
		clkclk=clkclk - 1;
		if(clkclk==0)
		begin
		I2Cclk=~I2Cclk;
		clkclk		=clock_div;
		end
end
else I2Cclk=1'b1; end
always @(posedge  I2Cclk )
if(reset)
begin
 chk				<=0;
 outreg			<=0;
 I2C_counter	<=0;
 bitaddrs7		<=4'b0001;
 Rxcount			<=0;
 slaveaddrs		<=0;
 ack				<=0;
 ack_count		<=0;
 I2Cclk			<=1;
 sda_int			<=1;
 clkclk			<=clock_div;
end
begin
////....................................state machine............................
case (state)
Rxidle:
				begin  		sda_int=1'b0;	//---------------------start sda = 0
				state			=Rxstart;end
Rxstart:
begin
		case(bitaddrs7)
		// initial frame 1001000 Initializing slave address
			1:	begin
				sda_int				=1'b1;//---------------------sda 1
				bitaddrs7=bitaddrs7+1; end
			2:	begin  sda_int		=1'b0;//---------------------sda 0
			3:	begin  sda_int		=1'b0;//---------------------sda 0
			4:	begin  sda_int		=1'b1;//---------------------sda 1
			5: begin	 sda_int		=1'b0;//---------------------sda 0
			6: begin	 sda_int		=1'b0;//---------------------sda 0
			7: begin sda_int		=1'b0;//---------------------sda=0
			8:	begin  sda_int		=1'b0;
				ack_count=2'b00;
				bitaddrs7=bitaddrs7+1;  // R/W  bit
											  end
			9: begin if(sda==1'b0)
				ack[0]=1;
				state=RxPointeraddr;			// Checking ack
				end
	endcase
end
RxPointeraddr:
	// Pointer Address 000000-00(P1P0) for temperature register
begin
		case(I2C_counter)
						//---------------------sda = 0
			0: begin	 sda_int		=1'b0;
				I2C_counter=I2C_counter+1;end
			1:	begin sda_int		=1'b0;
				I2C_counter=I2C_counter+1; end
			4: begin	 sda_int		=1'b0;
				ack_count=2'b01;
			8:	begin	if(sda==1'b0)
				ack[1]=1'b0; state=Rxstart1;end // after pointer register sda line acknoledged by a low	pulse
			endcase
end
//-----------------------------------start+ slave address byte---------------------
Rxstart1:
begin
		case(slaveaddrs)
		// initial frame 1001000 Initializing slave address including start  (case 0:)
			0: begin 			sda_int=1'b0;
				slaveaddrs=slaveaddrs+1; end
			1:	begin  sda_int		=1'b1;//---------------------sda 1
			8:	begin  sda_int		=1'b1;
				slaveaddrs=slaveaddrs+1;   // R/W  bit  high
				ack_count=2'b10;      end
				ack[2]=1;
				state=Rxdata;			// Checking ack
				end
	endcase
end
//----------------------------------Receiving Temperature Data --------------------------
Rxdata:
begin
	case(Rxcount)
		0: begin  outreg[15]=sda;
			Rxcount=Rxcount+1;end
		1: begin  outreg[14]=sda;
		2: begin  outreg[13]=sda;
		3: begin  outreg[12]=sda;
		4: begin  outreg[11]=sda;
		5: begin  outreg[10]=sda;
		6: begin  outreg[9]=sda;
		7: begin  outreg[8]=sda;
			Rxcount=Rxcount+1;
			ack_count=2'b11;   end
									// low pulse acknoledgment from TMP100
		8: begin  outreg[7]=sda;
			if(!sda) ack[2]=1;
		9: begin outreg[6]=sda ;
		10: begin outreg[5]=sda ;
		11: begin  outreg[4]=sda;
		12: begin  outreg[3]=sda;
		13: begin outreg[2]=sda;
		14: begin  outreg[1]=sda;
		15: begin sda_int=1'b0;
		 // checking low pulse acknoledge frm TMP 100
		state=Rxstop; end
		endcase
end
Rxstop:
begin  chk=1; sda_int=1'b1;  end
endcase
end
endmodule
Joe
eteam00
Instructor
Instructor
You have a 50MHz clock at your disposal.  This should allow you to set timing with 20nS (or even 10nS) granularity.
Why use SCL as a clock, when you can use the 50MHz clock (which generates SCL) as a clock?
You have multiple problems in plain view.
From the I2C specification, here is an excerpt:
3.1.3 Data validity
The data on the SDA line must be stable during the HIGH period of the clock. The HIGH or LOW state of the data line can only change when the clock signal on the SCL line is LOW (see Figure 4). One clock pulse is generated for each data bit transferred.
If you are going to use SCL as a clock to generate SDA output for data transfer (rather than START or STOP), then your use of the positive edge of SCL to generate SDA is a clear violation of the I2C specification, and represents a fundamental misunderstanding of the signal sequencing requirements.
Keep in mind that START and STOP requires SDA to change state when SCL is high, and data transfer requires SDA to change state when SCL is low.  Combined, these requirements prevent you from using SCL as a clock for generating SDA.
Please re-read some of the previous posts in this thread.  Your SDA implementation is not compliant with I2C electrical requirements.  You need to understand "open-drain" (or "open-collector") signaling.  Avrum's post in this thread emphasises quite clearly this same point.  Gabor includes a Verilog example of inferring open-drain signaling in his post in this thread.
Finally, your code will not synthesise in ISE.  One of the rules is that any single register can be defined (assigned a value) in only one process.  SDA_IN is the "output" of more than one process, for example.  You should be getting "multiple drivers" error messages from ISE.
From the New Users Forum README thread:
Common Interfaces and FPGA techniques:
I2C basics link#1 link#2 code examples    I2C spec Rev 4  wiki articles: I2C  SMBus  MDIO  SPD  EDID
So, you have multiple problems to overcome.  You should work with your instructor to learn the additional lessons in Verilog, hardware design, logic design, and state machine design you need to complete this project.  And you need to read and understand the I2C specification.
An I2C controller is an excellent project for learning these basic lessons.  Suggest you work on a single target device (e.g. TMP100 sensor) to keep the problem simple, and then add support for additional devices when the basic logic is verified to be working.
-- Bob Elkind
SIGNATURE:
Summary:
fradaric
Hii.. I got a new problem, while synthesising it shows an errer like
ERROR:Xst:899 - "i2Ccore.v" line 146: The logic for <chk1> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
ERROR:Xst:899 - "i2Ccore.v" line 146: The logic for <I2C_counter> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
ERROR:Xst:899 - "i2Ccore.v" line 146: The logic for <initialframe> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
ERROR:Xst:899 - "i2Ccore.v" line 146: The logic for <Rxcount> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
ERROR:Xst:899 - "i2Ccore.v" line 146: The logic for <slaveaddrs> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
ERROR:Xst:899 - "i2Ccore.v" line 146: The logic for <sda_init> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
ERROR:Xst:899 - "i2Ccore.v" line 146: The logic for <S_machine> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
ERROR:Xst:899 - "i2Ccore.v" line 146: The logic for <outreg[15]> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
ERROR:Xst:899 - "i2Ccore.v" line 146: The logic for <outreg[14]> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
ERROR:Xst:899 - "i2Ccore.v" line 146: The logic for <outreg[13]> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
ERROR:Xst:899 - "i2Ccore.v" line 146: The logic for <outreg[12]> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
ERROR:Xst:899 - "i2Ccore.v" line 146: The logic for <outreg[11]> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
ERROR:Xst:899 - "i2Ccore.v" line 146: The logic for <outreg[10]> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
ERROR:Xst:899 - "i2Ccore.v" line 146: The logic for <outreg[9]> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
ERROR:Xst:899 - "i2Ccore.v" line 146: The logic for <outreg[8]> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
ERROR:Xst:899 - "i2Ccore.v" line 146: The logic for <outreg[7]> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
ERROR:Xst:899 - "i2Ccore.v" line 146: The logic for <outreg[6]> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
ERROR:Xst:899 - "i2Ccore.v" line 146: The logic for <outreg[5]> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
ERROR:Xst:899 - "i2Ccore.v" line 146: The logic for <outreg[4]> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
ERROR:Xst:899 - "i2Ccore.v" line 146: The logic for <outreg[3]> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
ERROR:Xst:899 - "i2Ccore.v" line 146: The logic for <outreg[2]> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
ERROR:Xst:899 - "i2Ccore.v" line 146: The logic for <outreg[1]> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
ERROR:Xst:899 - "i2Ccore.v" line 146: The logic for <outreg[0]> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
How can I solve this ...here is my I2C code
// Company:
// Engineer:
// Create Date:    09:57:41 08/28/2012
// Design Name:
// Module Name:    i2Ccore
// Project Name:
// Target Devices:
// Tool versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module i2Ccore(
    inout sda,
    output scl,
    input reset,
    input clk,
    output [15:0] outputt
parameter clock_div1=250;
reg I2Cclk				=1'b1;  // I2C clock
reg [8:0] clkclk		=clock_div; // in order to divide 50MHz clock
reg sda_init				=1'b1; // making SDA high in initial state
reg [7:0] countdly	=0;
reg  dly					=0;
reg [7:0] clkclk1=250;
reg I2Cclk1				=1'b1;
reg chk					=0;
reg chk1					=0;
reg scl1					=1;
reg str					=0;
wire sda_int_start=1;
reg [3:0] initialframe	=0; // initializing via giving slave address(1001000-0(R/W))
reg [4:0] Rxcount		=0; // counter for data
reg [3:0] slaveaddrs	=0; // TMP 100 10010001
parameter Rxreset			=0;
parameter RxPointeraddr	=1;
parameter RxConfig		=2;
parameter Rxstart1		=3;
reg [2:0] S_machine 		=0; // For State machine starting
assign scl					=I2Cclk;  // Generated Clock for I2C
assign  outputt		   =outreg;  // output from TMP 100
assign sda					=sda_init; // Using SDA pin as inout
always @(posedge clk)
begin
if(!str)
	begin
	dly=0;
	countdly=countdly+1;
	if(countdly==250)
		begin
			dly=1;
		end
	end
end
begin
	if(chk)
		begin
			scl1=~I2Cclk  & I2Cclk1;
		end
	else if(!chk)
		begin
			scl1=I2Cclk1;
		end
end
begin
	clkclk1 = clkclk1 - 1;
	if (!clkclk1)
		begin
			I2Cclk1=~I2Cclk1;
			clkclk1 = clock_div1;
      end
end
begin
if(chk)
	begin
	clkclk		=clkclk - 1;
		if(clkclk==0)
			begin
				I2Cclk		=~I2Cclk;
				clkclk		=clock_div;
			end
	end
 else if(chk1==1)  I2Cclk	=1'b1;
end
begin
if(dly)
	begin
		//sda_int    =1'b0;
		chk         =1;
		str			=1;
	end
end
always @(posedge scl1 or posedge chk)
begin
case (S_machine)
Rxreset:
//if(scl1)
			begin
			if(reset)
				begin
					chk1				=0;
					I2C_counter		=0;
					initialframe	=0;
					Rxcount			=0;
					slaveaddrs		=0;
				end
		if(dly) begin
				sda_init   				=1'b0;
				S_machine				=RxPointeraddr;
				  end
		end
RxPointeraddr:
	begin
	case(initialframe)
					0: begin 	sda_init				=1'b1;//---------------------sda 1
						initialframe=1; end
				   1: begin  sda_init		=1'b0;//---------------------sda 0
						initialframe=2; end
					2:	begin  sda_init		=1'b0;//---------------------sda 0
						initialframe=3; end
					3:	begin  sda_init		=1'b1;
						sda_init		=1'b1;
						initialframe=4; end
					4: begin	 sda_init		=1'b0;//---------------------sda 0
						initialframe=5; end
					5: begin	 sda_init		=1'b0;//---------------------sda 0
						initialframe=6; end
					6: begin sda_init		=1'b0;//---------------------sda=0
						initialframe=7; end
					7:	begin sda_init		=1'b0;// R/W  bit
						initialframe=8; end
						S_machine=RxConfig;   end// Checking ack
		endcase
end
RxConfig:
		begin
				case(I2C_counter)
					0: begin	 sda_init		=1'b0;
					3:	begin  sda_init		=1'b0;
						//ack_count=2;
						S_machine=Rxstart1;           end // after pointer register sda line acknoledged by a low	pulse
					endcase
			end
Rxstart1:
		begin
		case(slaveaddrs)
					0: begin 			sda_init=1'b0;
					1:	begin  sda_init		=1'b1;//---------------------sda 1
					3:	begin  sda_init		=1'b0;//---------------------sda 0
					4:	begin  sda_init		=1'b1;//---------------------sda 1
					6: begin	 sda_init		=1'b0;//---------------------sda 0
					7: begin  sda_init		=1'b0;//---------------------sda=0
					8:	begin  sda_init		=1'b1;
						slaveaddrs=slaveaddrs+1; end // R/W  bit  high
						S_machine=Rxdata;				 end	// Checking ack
				endcase
		end
Rxdata:
begin
			case(Rxcount)
					if(sda==1'b0)
				15: begin outreg[0]=sda;
				16: begin if(sda==1'b0)
					S_machine=Rxstop; 		end
			endcase
		end
Rxstop:
		begin    chk1=1;
		   sda_init=1'b1;
			S_machine = Rxreset;
		end
endcase
end
endmodule
Joe
fradaric
Here is the wave form i've obtained...with the above code
Joe
eteam00
Instructor
Instructor
I got a new problem
Yes, you do have a new problem!
What was going through your mind when you wrote the following line of code?
This is a common newbie error by students who know very little about real FPGA hardware.
-- Bob Elkind
SIGNATURE:
Summary:
fradaric
Thanks for the reply,
I need to provide the start sgnal as per the protocol, the reg chk will change only once in my code ( becomes high after startup which will  provide  a delay for changing sda to low I guess  ) that is why I put like that. What  can I do now.
I dunno where to start what to do , there is no instructer for me to work on FPGA. If you don't mind provid me few resourses. I would be grateful to you if you could help me.
Fradaric.
Joe
eteam00
Instructor
Instructor
Another problem:
  • The unbuffered output of a LUT or a register is not suitable for use as a clock.  Normal logic interconnect has too much skew for clocking purposes.  You must use a clock buffer to distribute a low-skew clock.
But this does not suggest that the use of sc11 and chk signals as a clock is a good idea -- it is not a good idea.  You should be clocking everything with a single clock.
-- Bob Elkind
SIGNATURE:
Summary:
eteam00
Instructor
Instructor
One of the lessons you should learn is called synchronous single-clock logic design.  This means you use a single clock (and a single edge of this clock) to clock everything.  Your job, as designer, is to use this one clock to provide all the controls and generate all the outputs you need, in the proper sequence.
Accept this as a challenge:  Re-design your controller logic to use the one 50MHz clock at your disposal.
Returning to your original problem, you need to understand that individual FPGA registers are not capable of using multiple clocks.  Only one clock signal -- and one clock edge -- can be used to clock any single FPGA register.  The synthesiser complained because you described a hardware circuit which does not exist: registers with two clocks (scl1 and chk, in this case).
How does the prospect of 30 or 50 different forum folks giving you advice at the same time, all with different styles and ideas?  How do you like the idea of having 30 or 50 wives, and they are all giving you (different) advice on what to eat for breakfast and which colour shirt to wear?
  • Take some courses.
  • Get a job near folks who can teach or guide you.
Learning how to design logic hardware on a user forum works about as well as learning how to drive an auto on a user forum.  It is little fun, it is frustrating, and it takes forever.  If you don't value your time (or ours), the cost is pretty cheap.
Your friends and family are probably relieved that you aren't trying to learn medicine or dentistry on an online user forum, just hardware logic design.
I shouldn't be discouraging you, I should be encouraging you.  For this, I apologise.  If you are clever, persistent, and eager to learn, you will succeed.  You won't get a 5000 word lecture essay in response to every one of your posts.   But if you ask specific questions, you should not lack for brief but useful answers.
Have you read the New Users Forum README thread?  There are some links to tutorial sites and beginners projects which might be helpful or interesting...
-- Bob Elkind
SIGNATURE:
Summary:
inflector
In case anyone finds this thread five years later...
I found the four tutorials on i2c with Vivado by Tom Briggs to be quiet excellent. https://www.youtube.com/watch?v=skkyudHHSWY&t=978s
He does not discuss how to do the pulldowns but he covers clocks quite nicely and shows how to make a clock-divider module that outputs a 100khz output for i2c from another starting system synchronous clock like the 100Mhz default for the Artix Arty I'm using for my learning. He also shows how to use dual-clock Xilinx IP for buffered writes to i2c which is useful for many other things when crossing clock domains.
For testing the pulldown acknowledge, I implemented an i2c test slave as per the suggestions by @gszakacshere above by that I instantiate and connect to sda and scl which pulls down sda for the ack:
module i2c_test_slave(
    input wire reset,
    input wire scl,
    inout wire sda
localparam STATE_WAIT_START = 0;
localparam STATE_ADDRESS = 1;
localparam STATE_RW_BIT = 2;
localparam STATE_WAIT_ACK = 3;
localparam STATE_DATA = 4;
localparam STATE_WAIT_ACK_2 = 5;
localparam STATE_STOP = 6;
localparam HIGH = 1;
localparam LOW = 0;
localparam TRUE = 1;
localparam FALSE = 0;
localparam READ = LOW;
localparam WRITE = HIGH;
reg[4:0]    state;
reg[3:0]    bit_count;
reg[6:0]    address;
reg         read_write_bit;
reg[7:0]    data;
reg write_ack = FALSE;
assign sda  = write_ack ? LOW : 1'bz;
always @(negedge sda) begin
    if (reset == HIGH) begin
        state <= STATE_WAIT_START;
        bit_count <= 0;
    end else begin
        if (state == STATE_WAIT_START) begin
            state <= STATE_ADDRESS;
            bit_count <= 6;
            address = 7'bx;
        end
    end
end
always @(posedge sda) begin
       bit_count <= 0;
   end else begin
       if (state == STATE_STOP && scl == HIGH)
   end
end
always @(posedge scl) begin
        bit_count <= 0;
    end else begin
        case (state)
            STATE_WAIT_START: ;
                // Set in negedge sda above
            STATE_ADDRESS: begin
                address[bit_count] <= sda;
                if (bit_count == 0)
                    state <= STATE_RW_BIT;
                bit_count <= bit_count - 1;
            end
            STATE_RW_BIT: begin
                read_write_bit <= sda;
                state <= STATE_WAIT_ACK;
                write_ack <= TRUE;
            end
            STATE_WAIT_ACK: begin
                write_ack <= FALSE;
                state <= STATE_DATA;
                bit_count <= 7;
                data = 8'bx;
            end
            STATE_DATA: begin
                data[bit_count] <= sda;
                if (bit_count == 0) begin
                    state <= STATE_WAIT_ACK_2;
                    write_ack <= TRUE;
                end
            end
            STATE_WAIT_ACK_2: begin
                write_ack <= FALSE;
                state <= STATE_STOP;
            end
            STATE_STOP: begin
            // state <= STATE_IDLE;
            // this is set above checking posedge sda
            end
        endcase
    end // not reset
end // on rising clock
endmodule
