ljcg100@163.com
IES simulation using xilinx IP core
Hi~ I want to transplant xlinx floating point IP core to IES. I have added *_sim_netlist.v in the IES simulation. But I meet the errors below.
ncelab: *E,CUVMUR: instance '{*Name Protected*}' of design unit '{*Name Protected*}' is unresolved in '{*Name Protected*}.{*Name Protected*}:{*Name Protected*}'.
ncelab: *N,CUVPRO: For the above CUVMUR error message, the problem occurred in module declared in file /dirction/fc_add_sim_netlist.v.
Can someone give me help on this problem?
rshekhaw
Hi ljcg100@163.com ,
Did you compile simulation libraries successfully with compile_simlib Tcl command?
Please check comile_simlib logs, are there any errors there?
Please ensure the environment variables are set up correctly.
Also let us know which tool versions are you working with?
Raj
shameera
Prior to the above suggestions please make sure that you are using the compatible IES version with Vivado. Due to incompatible simulator version too these issues might occur.
