[IP_Flow 19-3389] Failed to import IP file. ( simulation source can not add )
I have an AXI FIFO IP in the design files. I want to make some simulations by using this AXI FIFO IP in the design sources.
I tried to add this 'AXI FIFO IP' into simulation sources. Received an critical warning : [IP_Flow 19-3389] Failed to import IP file 'C:/......../fifo.xci'  : IP name 'fifo.xci' is already in use in this project. Please choose a different name.
But I want to add 'AXI FIFO IP in the design files' into the simulation source directly. I dont want to add a new fifo into simulation source. Is there any way to overcome this problem?
Best Regards,
Tags (3)
Re: [IP_Flow 19-3389] Failed to import IP file. ( simulation source can not add )
@doner_t,
Check this forum thread:
https://forums.xilinx.com/t5/Vivado-TCL-Community/Cannot-run-import-ip-twice/td-p/603470
--Syed
@doner_t,
--Syed
Hi @doner_t,
Did you try to instantiate the IP directly in your test bench? I should work if the IP is already included in you vivado project.
Florent
Florent
Hello @florentw,
Yes. I instatiated the IP directly in test bench. Still it was not seen in simulation sources. I just wanted to make some simulations by using Axi-FIFO IP where is already in design sources. So,  I created a new project, and add all design sources in the previous project into the this new one. Then I could see now AXI FIFO IP in simulation sources.
Thank you,
