xxst120@123
ISIM 0X problem
Ib the following code in ISIM , I have a problem with "Sel" .In Isim, it appears 0x and doesn't work properly. Could you give me a solution,please? ---Thanks
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--USE ieee.numeric_std.ALL;
ENTITY prueba2 IS
END prueba2;
ARCHITECTURE behavior OF prueba2 IS
-- Component Declaration for the Unit Under Test (UUT)
COMPONENT mux4a1
PORT(
I1 : IN std_logic_vector(7 downto 0);
I2 : IN std_logic_vector(7 downto 0);
I3 : IN std_logic_vector(7 downto 0);
I4 : IN std_logic_vector(7 downto 0);
E : IN std_logic;
sel : INOUT std_logic_vector(1 downto 0);
F : OUT std_logic_vector(7 downto 0)
END COMPONENT;
--Inputs
signal I1 : std_logic_vector(7 downto 0) := (others => '0');
signal I2 : std_logic_vector(7 downto 0) := (others => '0');
signal I3 : std_logic_vector(7 downto 0) := (others => '0');
signal I4 : std_logic_vector(7 downto 0) := (others => '0');
signal E : std_logic := '0';
signal sel : std_logic_vector(1 downto 0) := (others => '0');
--Outputs
signal F : std_logic_vector(7 downto 0);
-- No clocks detected in port list. Replace <clock> below with
-- appropriate port name
-- constant <clock>_period : time := 100 ns;
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: mux4a1 PORT MAP (
I1 => I1,
I2 => I2,
I3 => I3,
I4 => I4,
E => E,
sel => sel,
F => F
-- -- Clock process definitions
-- <clock>_process :process
-- begin
-- <clock> <= '0';
-- wait for <clock>_period/2;
-- <clock> <= '1';
-- end process;
-- Stimulus process
stim_proc: process
begin
I1 <= "10000001";
I2 <= "10000000";
I3 <= "10000010";
I4 <= "11000001";
Sel <="00";
E <='0';
wait for 500 ns;
end process;
stim_proc1: process
begin
I1 <= "10000001";
I2 <= "10000000";
I3 <= "10000010";
I4 <= "11000001";
Sel <="01";
E <='0';
wait for 500 ns;
end process;
END;
gszakacs
Professor
Professor
Even in a test bench it's best to only drive a signal from one process.  If you want to first make the signal low and then later make it high you can simply continue the first process with a state change after the wait statement like:
stim_proc: process
begin
I1 <= "10000001";
I2 <= "10000000";
I3 <= "10000010";
I4 <= "11000001";
Sel <="00";
E <='0';
wait for 500 ns;
I1 <= "10000001";
I2 <= "10000000";
I3 <= "10000010";
I4 <= "11000001";
Sel <="01";
E <='0';
wait for 500 ns;
end process;
END;
-- Gabor
avrumw
Guide
Guide
I am NOT a VHDL expert, but...
If I interpret your code properly, the two processes, stim_proc1 and stim_proc2 will start at the same time. The first one drives Sel to 00, and the second one drives it to 01. Together, they resolve to 0x
Avrum
xxst120@123
Yes , I know 0x assume 00/01 but I want to see them in two separate time frames. But they mix themselves inA one, showing me "0x".Is there any way to see them in two parts?
PS: Do I have to check the clock or something like that ?
Thanks for answering .
gszakacs
Professor
Professor
stim_proc: process
begin
I1 <= "10000001";
I2 <= "10000000";
I3 <= "10000010";
I4 <= "11000001";
Sel <="00";
E <='0';
wait for 500 ns;
I1 <= "10000001";
I2 <= "10000000";
I3 <= "10000010";
I4 <= "11000001";
Sel <="01";
E <='0';
wait for 500 ns;
end process;
END;
-- Gabor
xxst120@123
Thank you ,sir.
