kpatel94126
ISIM FATAL ERROR
Ther attached code fails to simulate with ISIM with the following error message
ERROR: In process xyz.vhd:read_cmd
 FATAL ERROR:ISim: This application has discovered an exceptional condition from which it cannot recover. Process will terminate....
This code is a testbench for an up/down counter. The driving commands and test vectors are read from text file commands.txt. commands include reset, load, check, count etc..
The issue arises when my command.txt file contains an unexpected cmd i.e when "others =>" is exercised from the case statement.
Any ideas why this might be?
anusheel
@kpatel94126
Can you share command.txt file?
Anusheel
Helpful answer -> Give Kudos
vijayak
Hi @kpatel94126
I get the following warning with Vivado and looks like the counter module is missing.
WARNING: [VRFC 10-122] counter remains a black-box since it has no binding entity.
Please post the complete project archive.
Thanks,Vijay
vijayak
Hi @kpatel94126
Did you resolve the issue? Please update us with the status.
Thanks,Vijay
