ISim: Is there a way to automatically load a waveform setup for a session?
Hi Folks,
I've attempted to answer this myself but with no luck.  Here's what I want to do and I'm hoping someone can point me in the right direction.
I have an ISE project with a simulation testbench.  When I perform Behavioral Simulation, I want the simulator to open and load the desired signal names in the waveform viewer, include the correct order, radix settings and color.  I know how to do this for ModelSim, but can't seem to figure this out for ISim.
Any recommendations?
Re: ISim: Is there a way to automatically load a waveform setup for a session?
Any changes to the waveform during an ISim session are recalled when you re-launch the simulation. There's no need for saving the configuration.
If you are seeing that ISim is not remembering the wave configuration, perform a Project --> Clean Up Project Files process in order to flush previusly generated ISim files.
Hope this helps.
Eddie
