shashankbr
ISim launch from XPS
I am able to generate the HDL files in a XPS running on Virtual box. But the Launch HDL simulator elaborates the ELF file and in the end stops with the following message
xterm -e ./isim_{yourfilenamehere} -gui -tclbatch {yourfilenamehere}_setup.tcl &
Done!
How do I workaround this problem and launch ISim?
shashankbr
Solved this.. Install xterm on your VM
shashankbr
shashankbr
open xps from the xterm terminal and continue your work as it is
