Newbie meldm
In simulation getting U as output
I'm new to xilinx. I have 2 outputs and In my simulation I get 'U' for one of them. Please help me to solve this. Here is my code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity bitSliceCode is
   Port ( M : in STD_LOGIC;
        S0 : in STD_LOGIC;
        S1 : in STD_LOGIC;
        A : in STD_LOGIC;
        B : in STD_LOGIC;
        Cin : in STD_LOGIC;
        F : out STD_LOGIC;
        Cout : out STD_LOGIC);
end bitSliceCode;
architecture Behavioral of bitSliceCode is
begin
Mux: process(M) is
    begin
        if ( M='0' and S1='0' and S0='0' ) then
                F <= A and B ;
       elsif ( M='0' and S1='0' and S0='1' ) then
                F <= A or B ;
       elsif ( M='0' and S1='1' and S0='0' ) then
                F <= A xor B ;
       elsif ( M='0' and S1='1' and S0='1' ) then
                F <= A xnor B ;
       else
                F <= '0';
               Cout <='1';
       end if;
end process;
end Behavioral;
and the sim code:
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
ENTITY bitSim IS
END bitSim;
ARCHITECTURE behavior OF bitSim IS
COMPONENT bitSliceCode
PORT(
M : IN std_logic;
S0 : IN std_logic;
S1 : IN std_logic;
A : IN std_logic;
B : IN std_logic;
Cin : IN std_logic;
F : OUT std_logic;
Cout : OUT std_logic
END COMPONENT;
signal M : std_logic := '0';
signal S0 : std_logic := '0';
signal S1 : std_logic := '0';
signal A : std_logic := '0';
signal B : std_logic := '0';
signal Cin : std_logic := '0';
signal F : std_logic;
signal Cout : std_logic;
constant clock_period : time := 10 ns;
BEGIN
uut: bitSliceCode PORT MAP (
M => M,
S0 => S0,
S1 => S1,
A => A,
B => B,
Cin => Cin,
F => F,
Cout => Cout
stim_proc: process
begin
M <= '0'; S1 <='0'; S0 <='0'; A <='1'; B <='1';
wait for clock_period;
M <= '0'; S1 <='0'; S0 <='0'; A <='1'; B <='0';
M <= '0'; S1 <='0'; S0 <='0'; A <='0'; B <='1';
M <= '0'; S1 <='0'; S0 <='0'; A <='0'; B <='0';
M <= '0'; S1 <='0'; S0 <='1'; A <='0'; B <='0';
M <= '0'; S1 <='0'; S0 <='1'; A <='1'; B <='0';
M <= '0'; S1 <='0'; S0 <='1'; A <='0'; B <='1';
M <= '0'; S1 <='0'; S0 <='1'; A <='1'; B <='1';
M <= '0'; S1 <='1'; S0 <='0'; A <='0'; B <='0';
M <= '0'; S1 <='1'; S0 <='0'; A <='1'; B <='0';
M <= '0'; S1 <='1'; S0 <='0'; A <='0'; B <='1';
M <= '0'; S1 <='1'; S0 <='0'; A <='1'; B <='1';
M <= '0'; S1 <='1'; S0 <='1'; A <='1'; B <='1';
M <= '0'; S1 <='1'; S0 <='1'; A <='1'; B <='0';
M <= '0'; S1 <='1'; S0 <='1'; A <='0'; B <='1';
M <= '0'; S1 <='1'; S0 <='1'; A <='0'; B <='0';
M <= '0';
wait;
end process;
END;
Re: In simulation getting U as output
Hi @meldm,
The output Cout is shown as U because you haven't covered the scenario in your test bench when the value for Cout gets assigned.
So, run simulation after using the below statements in your test bench so that it covers the condition for Cout to get assigned.
M <= '1';
When M is 1 then the condition in the UUT executes and assigns the value to Cout.
Thanks & Regards,
A.Shameer
Newbie meldm
Thank you very much for help but I get U for output F. There isn't any problem with Cout. Do you have any idea why this could happen?
Scholar richardhead
Because you are missing signals from the sensitivity list in the mux process. Currently it is only sentitive to M, and M initialises to 0 and is '0' throughout, so there are no 'event on M, and nothing will be muxed.
You need to add S0, S1, A and B to the sensitivity list.
