hwtodt
Library "unisim" storage location
I want to run the logic simulation of Xilinx IP (MMCM). The simulation uses the batch mode of the modelsim.
Currently, the following command has been executed.
   vcom  ./clk_wiz_0_2/clk_wiz_0_sim_netlist.vhdl
As a result, the following error is output:
  ** Error: ./clk_wiz_0_2/clk_wiz_0_sim_netlist.vhdl(15): (vcom-1598) Library "unisim" not found.
  ** Error: ./clk_wiz_0_2/clk_wiz_0_sim_netlist.vhdl(16): (vcom-1136) Unknown identifier "UNISIM".
I do not know the location of Library "unisim". Please tell me the storage place of "unisim".
For reference, I attached the following.
 Error log (log.txt)
 Simulation environment (sim.zip)
 Project file (project_2.xpr.zip)
drjohnsmith
I think you need to compile and add the unism lib
its some where in the docs, but this might help
https://electronics.stackexchange.com/questions/60319/how-to-add-the-xilinx-library-to-modelsim
hwtodt
Thank you for your answer.
The attached docs are written for ISE. I want to know where Vivado unisim is.
Please tell me the unisim location in vivado.
graces
Did you run compile_simlib to pre-compile Vivado simulation libraries successfully? If yes, make sure you copy the generated modelsim.ini to the current simulation directory so that library are correctly mapped.
The source files for library "unisim" is located at Vivado install area:
<Vivado_Install_Dir>/data/vhdl/src/unisims
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs.
drjohnsmith
You need to compile the unisim libs in vivado just as you do in ISE.
