inflector
Misleading error message for extra comma at end of ports list for module instance
If you have an extra comma at the end of the port list in a module instantiation, like this:
i2c_fifo fifo (
.srst(reset | clear),
.clk(clock),
.wr_en(fifo_write_enable),
.rd_en(fifo_read_enable),
.din(fifo_data_in),
.dout(fifo_data_out),
.full(fifo_full),
.empty(fifo_empty),
You get this error: "Error: ordered port connections cannot be mixed with named port connections". I got this when I first started using Vivado a few months back and spent an hour or two trying to figure out what was wrong with my naming or the ports list. Then I wondered if the last comma was the problem and took away, like:
i2c_fifo fifo (
.clk(clock),
.din(fifo_data_in),
.full(fifo_full),
.empty(fifo_empty)
NOTE: the lack of a comma after .empty(fifo_empty)
This is correct but the error is very misleading.
peadard
@dpaul24, @inflector, I reproduced the issue and have documented it in AR# 70145. The AR needs to go through the formal publishing process before it will be available on xilinx.com.
dpaul24
This is a perception issue.
I find no problem with the message "You get this error: "Error: ordered port connections cannot be mixed with named port connections".
Whenever I get such a msg, I would look at my port connections, and the extra comma would be outright visible. Actually I am much more cautious, so that I don't have to rely on tool messages to debug my code. I will write the instiantiation like this. Your chances of mistake are greatly reduced! :-)
i2c_fifo fifo (
.srst(reset | clear)      ,
.clk(clock)               ,
.wr_en(fifo_write_enable) ,
.rd_en(fifo_read_enable)  ,
.din(fifo_data_in)        ,
.dout(fifo_data_out)      ,
.full(fifo_full)          ,
.empty(fifo_empty)
And yes I use Notepad++, which is a great ext editor!
Working for a small company, I think many engineers like me are too much dependent on Vivado to get their projects going on time. We really don't have much to say. Even if such things are reported, as I have been seeing from 2014, no one here cares much!
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
peadard
cleonjones
Another way to get this error message (in Verilog) is to forget the period in front of the port during assignment:
i2c_fifo fifo (
   srst(reset)              , // BAD, should be .srst(reset)
   clk(clock)               , // etc
   din(fifo_data_in)        ,
   full(fifo_full)          ,
   empty(fifo_empty)
I agree the error message could be a bit more helpful.
nikkimarrow
thank you.
