Mismatch between AXI front door write and backdoor_memory_read
I am using 2018.2 Vivado and have the Xilinix AXI slave VIP integrated in the testbench.
When the DUT (master) does a (front door) write and read to a address location, the write and read values match. But, from the TB when I use "backdoor_memory_read" to read the address written by the DUT, the read back value is a random value and is NOT the value the DUT wrote. The DUT is not doing any address translation.
Any idea why do I see a mis-match between front door write and backdoor read of the same address location?
I would have to go digging through our code to be sure but I believe the backdoor tasks are are interface width addresses but AXI is byte addressed.
That is with a 64-bit AXI the address of 0x10 is backdoor address 2.  This would probably be because the backdoor doesn't have the ability to write less than the interface width.
