mountain902
Missing files in ISE post route simulation
Hi, I am using ISE design tool,
as I did some behavioral modeling to my designs,
but when i move to post route simulation,
please let me know if u know the reason and t any suggested solutions,
Thank you
Sean
bandi
Hi @mountain902,
Are you facing any errors while simulating the test bench of the design due to missing files? Can you please try creating the project from scratch and then try simulating the design.
Can you please share the archived project or a test case to check at our end on why and which files are missing.
Thanks & Regards,
Sravanthi B
