Participant scmicron
Missing ports in AXI VIP
Dear all,
I am using AXI VIP to verify our AXI4 Full Slave peripheral. I generated the VIP design example, and then modified the generated files to suit my needs. However, I can see that the VIP (configured as Master) does not have the following ports: ARSIZE and AWSIZE.
Why? How is it able to determine the size of each beat? How am I supposed to add it?
Many thanks
Cheers
Simone
Re: Missing ports in AXI VIP
Hi @scmicron,
Are you sure the VIP has been configured as full AXI4?
Try not to use the Auto configuration in the VIP GUI. Try to force it in manual.
PS: I didn't had time to work on your other issue yesterday. I will do it today.
Florent
Florent
Hi @scmicron,
Florent
Florent
Hi Florent!
Good to hear ;)
I checked and indeed this problem is due to the wrong settings in the GUI.
Cheers
Simone
