gg9132qq
Module parameter '<protected>' not found for override.
I am using vivado 2017.1 and modelsim 10.5 for my design.And I need to use the module and IP written by my colleague which designed and verified in vivado 2015.1
I had pre-compiled lib by modelsim 10.5,listed below:
; modelsim 10.5 pre-compile vivado 2015.1 lib
secureip_151_105 = D:/Xilinx/vivado/2015.1/compile_simlib_151_105/secureip
unisim_151_105 = D:/Xilinx/vivado/2015.1/compile_simlib_151_105/unisim
unimacro_151_105 = D:/Xilinx/vivado/2015.1/compile_simlib_151_105/unimacro
unifast_151_105 = D:/Xilinx/vivado/2015.1/compile_simlib_151_105/unifast
unisims_ver_151_105 = D:/Xilinx/vivado/2015.1/compile_simlib_151_105/unisims_ver
unimacro_ver_151_105 = D:/Xilinx/vivado/2015.1/compile_simlib_151_105/unimacro_ver
unifast_ver_151_105 = D:/Xilinx/vivado/2015.1/compile_simlib_151_105/unifast_ver
simprims_ver_151_105 = D:/Xilinx/vivado/2015.1/compile_simlib_151_105/simprims_ver
; modelsim 10.5 pre-compile vivado 2017.1 lib
secureip = D:/Xilinx/vivado/2017.1/compile_simlib_171/secureip
unisim = D:/Xilinx/vivado/2017.1/compile_simlib_171/unisim
unimacro = D:/Xilinx/vivado/2017.1/compile_simlib_171/unimacro
unifast = D:/Xilinx/vivado/2017.1/compile_simlib_171/unifast
unisims_ver = D:/Xilinx/vivado/2017.1/compile_simlib_171/unisims_ver
unimacro_ver = D:/Xilinx/vivado/2017.1/compile_simlib_171/unimacro_ver
unifast_ver = D:/Xilinx/vivado/2017.1/compile_simlib_171/unifast_ver
simprims_ver = D:/Xilinx/vivado/2017.1/compile_simlib_171/simprims_ver
xpm = D:/Xilinx/vivado/2017.1/compile_simlib_171/xpm
then the .do file : I had used all pre-compiled lib needed.
vsim -voptargs="+acc" -L blk_mem_gen_v8_3_6 -L xil_defaultlib -L blk_mem_gen_v8_2 -L fifo_generator_v12_0 -L srio_gen2_v3_3 -L fifo_generator_v13_1_4 -L unisims_ver_151_105 -L unimacro_ver_151_105 -L secureip_151_105 -L unisims_ver -L unimacro_ver -L secureip -L xpm -lib xil_defaultlib xil_defaultlib.tb_dat_to_dsp_cvt xil_defaultlib.glbl
then the error occur:
# ** Error (suppressible): (vsim-3584) <protected>(<protected>): Module parameter '<protected>' not found for override.
# Time: 0 fs Iteration: 0 Protected: /uut1/ch1_fifo/inst/<protected>/<protected> File: ../../../../../IPCore/srio_gen2_0/fifo_generator_v12_0/simulation/fifo_generator_vlog_beh.v
# Time: 0 fs Iteration: 0 Protected: /uut1/ch2_fifo/inst/<protected>/<protected> File: ../../../../../IPCore/srio_gen2_0/fifo_generator_v12_0/simulation/fifo_generator_vlog_beh.v
# Time: 0 fs Iteration: 0 Protected: /uut1/ch3_fifo/inst/<protected>/<protected> File: ../../../../../IPCore/srio_gen2_0/fifo_generator_v12_0/simulation/fifo_generator_vlog_beh.v
# Time: 0 fs Iteration: 0 Protected: /uut1/ch4_fifo/inst/<protected>/<protected> File: ../../../../../IPCore/srio_gen2_0/fifo_generator_v12_0/simulation/fifo_generator_vlog_beh.v
# Time: 0 fs Iteration: 0 Protected: /uut1/ch5_fifo/inst/<protected>/<protected> File: ../../../../../IPCore/srio_gen2_0/fifo_generator_v12_0/simulation/fifo_generator_vlog_beh.v
# Time: 0 fs Iteration: 0 Protected: /uut1/ch6_fifo/inst/<protected>/<protected> File: ../../../../../IPCore/srio_gen2_0/fifo_generator_v12_0/simulation/fifo_generator_vlog_beh.v
# Time: 0 fs Iteration: 0 Protected: /uut1/ch7_fifo/inst/<protected>/<protected> File: ../../../../../IPCore/srio_gen2_0/fifo_generator_v12_0/simulation/fifo_generator_vlog_beh.v
# Time: 0 fs Iteration: 0 Protected: /uut1/ch8_fifo/inst/<protected>/<protected> File: ../../../../../IPCore/srio_gen2_0/fifo_generator_v12_0/simulation/fifo_generator_vlog_beh.v
# Time: 0 fs Iteration: 0 Protected: /uut1/ch9_fifo/inst/<protected>/<protected> File: ../../../../../IPCore/srio_gen2_0/fifo_generator_v12_0/simulation/fifo_generator_vlog_beh.v
# Time: 0 fs Iteration: 0 Protected: /uut1/ch10_fifo/inst/<protected>/<protected> File: ../../../../../IPCore/srio_gen2_0/fifo_generator_v12_0/simulation/fifo_generator_vlog_beh.v
# Time: 0 fs Iteration: 0 Protected: /uut1/ch11_fifo/inst/<protected>/<protected> File: ../../../../../IPCore/srio_gen2_0/fifo_generator_v12_0/simulation/fifo_generator_vlog_beh.v
# Time: 0 fs Iteration: 0 Protected: /uut1/ch12_fifo/inst/<protected>/<protected> File: ../../../../../IPCore/srio_gen2_0/fifo_generator_v12_0/simulation/fifo_generator_vlog_beh.v
# Time: 0 fs Iteration: 0 Protected: /uut1/ch13_fifo/inst/<protected>/<protected> File: ../../../../../IPCore/srio_gen2_0/fifo_generator_v12_0/simulation/fifo_generator_vlog_beh.v
# Time: 0 fs Iteration: 0 Protected: /uut1/ch14_fifo/inst/<protected>/<protected> File: ../../../../../IPCore/srio_gen2_0/fifo_generator_v12_0/simulation/fifo_generator_vlog_beh.v
# Time: 0 fs Iteration: 0 Protected: /uut1/ch15_fifo/inst/<protected>/<protected> File: ../../../../../IPCore/srio_gen2_0/fifo_generator_v12_0/simulation/fifo_generator_vlog_beh.v
# Time: 0 fs Iteration: 0 Protected: /uut1/ch16_fifo/inst/<protected>/<protected> File: ../../../../../IPCore/srio_gen2_0/fifo_generator_v12_0/simulation/fifo_generator_vlog_beh.v
# Time: 0 fs Iteration: 0 Protected: /uut1/ch17_fifo/inst/<protected>/<protected> File: ../../../../../IPCore/srio_gen2_0/fifo_generator_v12_0/simulation/fifo_generator_vlog_beh.v
# Time: 0 fs Iteration: 0 Protected: /uut1/ch18_fifo/inst/<protected>/<protected> File: ../../../../../IPCore/srio_gen2_0/fifo_generator_v12_0/simulation/fifo_generator_vlog_beh.v
# Time: 0 fs Iteration: 0 Protected: /uut1/ch19_fifo/inst/<protected>/<protected> File: ../../../../../IPCore/srio_gen2_0/fifo_generator_v12_0/simulation/fifo_generator_vlog_beh.v
what should I do to fix it?
 i think ch1_fifo should not be fifo_generator_v12_0 because it generate by vivado which is fifo_generator_v13_1_4
dpaul24
I would first suggest you to upgrade the IPs (FIFOs in your case) and then retry.
Tools --> Report --> Report IP Status
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
gg9132qq
THE fifo was included in the ipcore srio_gen3_3 and protected.So you can not updata this fifo_12_0 separately.
