NIDRU instance (dru_v_9) is missing
VCS version = N-2017.12-SP2-2_Full64
Vivado version = Vivado 2018.3
I tried to simulate a design which has the Xilinx NIDRU.
When I browse the design hierarchy in VCS, I do not see INST_DRU under NIDRU_WRAPPER_V_2_1.
Do I need a .vp file?
Will someone from Xilinx please help me resolve this issue? This has become a show stopper for me. I suggest we have a Webex/Zoom meeting.
Thank You!
- S
bandi
Hi ssathe@ciena.com,
Can you please try exporting simulation scripts using export_simulation command from Vivado and try comparing your custom scripts with generated scripts to check if there are any missing commands or instances.
Thanks & Regards,
Sravanthi B
