Visitor karen254
Number of cycles required to simulate
I am working on Vivado 2018.3 and I am interested in knowing the number of cycles that my code requires to execute. However, in the Timing Report shown I don't see this information:
In Vivado HLS, starting from a C code, after the synthesis and the cosimulation, I am able to see the latency of the vhdl, as shown below. How can I see the same information in Vivado? In Vivado I have both the vhdl and its test bench.
Thanks in advance for the help!
Re: Number of cycles required to simulate
When you look at the waveform .. its the number of clocks between when you start whatever it is you are doing and when you finsh or get the answer.
Mike
Scholar richardhead
Its a fairly meaningless question - FPGAs and logic runs forever.
If you are looking for the latency, you can determine it from the testbench.
Visitor karen254
Thanks for your answer. Could you please tell me how to find the latency from the test bench?
Mike
回复: Number of cycles required to simulate
With regards to your timing summary report, 'inf' means the path is ignored.
Did you ever specify period constraint with create_clock in your constraint file?
Visitor karen254
@mike_james_lewis  Thank you! I now realize it was silly question, but this is the only way we have to learn, right? Thanks!!
Visitor karen254
@graces Thank you, I already took a look at it!
