Visitor mueller-fair
OBUFTE3.vhd and OBUFTDSE3.vhd in vhdl_analyze_order but files not available
I'm trying to compile the UNISIM library coming with vivado 2014.4 for a third-party simulator. Under
   <install_path>/data/vhdl/src/unisims/primitive
is a file
  vhdl_analyze_order
which contains the file names in compilation order.
The vhdl_analyze_order file contains
  OBUFTDSE3.vhd
  OBUFTE3.vhd
but these two files are missing in the primitives directory.
Any idea what is wrong here ?
Is the vhdl_analyze_order file out-dated ?
Or are two vhdl models missing ?
Re: OBUFTE3.vhd and OBUFTDSE3.vhd in vhdl_analyze_order but files not available
It does look that the vhdl_analyze_order is not in sync with the actual list of primitive. These two are UltraScale primitives.
Thanks for pointing it out. I'll file a CR.
