Observer stmilch
PlanAhead: No ram in microblaze simulation
I have a PlanAhead project with a microblaze in a lower instance. The processor works fine on hardware.
When I start a behavioral simulation the processor finds no ram data and steps to all the memory until it stalls at 0x10004. Even having valid data in the .mem files all input to the processor is zero, so I assume that this is interpreted all as nops and explains the behaviour of the processor.
I think all the block ram is not in the simulation model. During fuse.exe processing I get the following warnings:
Starting static elaboration
WARNING:HDLCompiler:89 - "C:/Projekte/tt/TT2177/fpga/ccu_pa/ccu_pa.srcs/sources_1/edk/mb77/simulation/behavioral/mb77.vhd" Line 2363: <mb77_microblaze_0_bram_block_wrapper> remains a black-box since it has no binding entity.
WARNING:HDLCompiler:746 - "C:/Applic/Xilinx/14.7/ISE_DS/EDK/hw/XilinxProcessorIPLib/pcores/axi_lite_ipif_v1_01_a/hdl/vhdl/slave_attachment.vhd" Line 260: Range is empty (null range)
Completed static elaboration
WARNING:Simulator:648 - "C:/Projekte/tt/TT2177/fpga/ccu_pa/ccu_pa.srcs/sources_1/edk/mb77/simulation/behavioral/mb77.vhd" Line 2363. Instance mb77_microblaze_0_bram_block_wrapper is unbound
Fuse is called this way:
C:\Applic\Xilinx\14.7\ISE_DS\ISE\bin\nt64\unwrapped\fuse.exe -intstyle pa -incremental -L work -L proc_sys_reset_v3_00_a -L lmb_v10_v2_00_b -L lmb_bram_if_cntlr_v3_10_c -L microblaze_0_bram_block_elaborate_v1_00_a -L microblaze_v8_50_c -L iomodule_v1_03_a -L proc_common_v3_00_a -L axi_lite_ipif_v1_01_a -L interrupt_control_v2_01_a -L axi_gpio_v1_01_b -L mdm_v2_10_a -L clock_generator_v4_03_a -L clock_generator_0_v4_03_a -L axi_interconnect_v1_06_a -L unisims_ver -L unimacro_ver -L xilinxcorelib_ver -L secureip -o TestCcuMb.exe --prj C:/Projekte/tt/TT2177/fpga/ccu_pa/ccu_pa.sim/sim_1/behav/TestCcuMb.prj -top work.TestCcuMb -top work.glbl
In the simulation hirarchy I find my microblaze (i_mb77) with its peripherals inclusive ilmb, dlmb, dram_ctrl for instruction and data, but NOT the expected bram_block!
Any ideas?
  Stefan
Observer stmilch
Re: PlanAhead: No ram in microblaze simulation
Thanks for your hint.
I MANUALLY added the wrapper to my design in the work library and so fuse.exe could bind them.
But still this seems to be a strange bug in PlanAhead/ISIM configuration.
Check if this helps.
http://www.xilinx.com/support/answers/34620.html
Thanks,Vijay
Observer stmilch
