Predefined constants/macros in xvlog?
Does anyone happen to know what the macro that 'identifies' xvlog is, if there is one? In other words, I want to write code that looks like
`ifdef __VIVADO__
...do something specific to xvlog/xsim
`else
...do something specific to other sims
`endif
I've tried lots of variations on the __VIVADO__ string above, with no luck.
Re: Predefined constants/macros in xvlog?
Hi @eml ,
XILINX_SIMULATOR is the XSIM predefined Verilog macro as shown in the below snippet
Please check page 165 of UG900 regarding the same.
Hi @eml ,
You can use xvlog -d option to specify the macro definition. Please check page 156 of UG900 regarding the same.
Hi Shameera - that's for user-defined macros, rather than built-in xvlog macros. It's common for Verilog vendors to have their own built-in (generally undocumented) macros. If I wanted to know that I was running on ModelSim, for example, I would test for 'MODEL_TECH'.
Hi @eml ,
Great - thanks.
