way2vipul
Problem with JK-Flipflop simulation with isim
Hello dear,
I created a schematic diagram for JK flip flop shown below.
then i made a test bench to test the JK flip flop. while i run the simulation it shows undefined q and Q0.
how to initialize the q and q0 i tryied following but did not get success still problem persist in the simulation please give me solution of this problem.
Thank you
vipul
gszakacs
Instructor
Instructor
Your "JK flip-flop" has no reset signal.  So the value of Q and Q0 are unknown at startup.  The feedback in the flop is such that no amount of wiggling the inputs will get it to a known state from this condition.  You have two possible solutions:
1) add reset circuitry to the flop and drive the reset active at the start of simulation.
2) Use "force" to set the Q or Q0 output to a known state briefly after startup.
I'm attaching a Verilog test bench that illustrates solution 2.
-- Gabor
hello,
i tried Jk flip flop by drawing schematic . I have solved the problem of inital output but i am not getting proper output for input j=k=1 that is it should toggle for particular clock=1 but i am not geeting ans as shown, Plz help
I have converted it in T flip flop.
fredjobsearch
I had the same problem. Finally getting around to making that gate level Apple II and couldn't find library of 74series parts. So have to make some.
Forcing didn't work for me on my JK flip flop which looked just like the one in the post.. Do you know why?? The clue is "DUMMY".
The schematic thing generates Verilog from the schematic. Those are in the ".vf" files. Some input and output can't be connected directly but require a wire be defined and it uses that. So internally the  Q  and Qnot or whatever signal he used are connected by the wire Q_DUMMY and Qnot_DUMMY. So forcing Q and Qnot only affects the output pins while forced but doesn't set Q_DUMMY and Qnot_DUMMY which remained "x" undefined.. So it doesn't work until forcing Q_DUMMY.
ma97
hi
I have the same problem
but i think this schematic that you draw is jk-latch; and you should follow as this pic
https://circuitdigest.com/electronic-circuits/jk-flip-flop-truth-table-working?destination=node/1424
but this schematic dose not work in ise too;
there is my schematic with testbench;
PLz everyone can help and make it complete
glszakacs
The schematic you've posted is too simple to work as an edge-triggered device.  It would need a pulse (edge-detector) to source the clock signal.  Here's a master-slave flip-flop:
There is a description of its operation at:
https://www.electronics-tutorials.ws/sequential/seq_2.html
ma97
very thanks; that's worked with master-slave (and added reset signal)
glszakacs
No problem.
By the way, I'm amazed at how much incorrect information I came accross looking for this schematic snippet.  The one from circuitdigest was just wrong - it should have NAND gates where it shows AND gates.  Even the master slave diagram I posted shows the clock as rising edge triggered, while the outputs actually toggle on the falling clock edge (the "master latch" toggles on the rising edge).  The clocks should be inverted to have rising edge outputs.  The lower NAND gates of each latch section can be increased to 3 inputs to add an active low reset signal.  Here's a Verilog description of the flip-flop with rising edge clock and active high reset:
`timescale 1ns / 1ps
`default_nettype none
module JK_ff
input wire j,
input wire k,
input wire clock,
input wire reset,
output wire Q,
output wire Q_not
wire j_NAND;
wire k_NAND;
wire slave_set_not;
wire slave_rst_not;
wire master_Q;
wire master_Q_not;
assign j_NAND = !(j & !clock & Q_not);
assign k_NAND = !(k & !clock & Q);
assign master_Q = !(j_NAND & master_Q_not);
assign master_Q_not = !(k_NAND & master_Q & !reset);
assign slave_set_not = !(master_Q & clock);
assign slave_rst_not = !(master_Q_not & clock);
assign Q = !(slave_set_not & Q_not);
assign Q_not = !(slave_rst_not & Q & !reset);
endmodule
`default_nettype wire
