Regarding File reading and writing in vivado simulation through Verilog RTL code
I'm reading a text (.txt) file hex data from directory using below command,
                a1=$fopen("test1.txt","r");
                a2=$fscanf(a1,"%h",reg1);
I'm writing a text (.txt) file to directory using below command,
                a1=$fopen("test1.txt","w");
                      $fdisplay(a1,"%h",reg2);
Here my question is how to read and write  RAW (.raw) files ...?
It's not working for
                a1=$fopen("test1.raw","r");
So,  how to read and write  RAW (.raw) files ...? give me any suggestions.
Scholar richardhead
Re: Regarding File reading and writing in vivado simulation through Verilog RTL code
you can open any file as binary instead of text. You need to open in binary mode:
a1 = $fopen("some_file", "rb"); //read mode, binary
$fread(some_variable, a1);
Scholar richardhead
same i used for writing
reg [16:0]reg_data;
a1 = $fopen("some_file.raw", "wb"); //write mode, binary
$fwrite(reg_data, a1);
it's not working.
Please give your suggestion...
