Observer mac004
Repeat an elaborate error. Vivado2017.3 Simulation
Hello.
I use Vivado2017.3.
Kintex-7 xc7k325tffg900-2
I start from Simulation in "Run Post-Synthesis Functional Simulation", but become the error.
I delete error message and start from the second Simulation.
Then there is no error of Simulation.
After Simulation was overI start from the third Simulation.
Howeverit becomes the error in the same way as the first.
I start from the fourth SimulationThere is no error.
I do not change the source file.
Why?
Does one of two times of why become the error?
I attach log file.
Sincerely,
Re: Repeat an elaborate error. Vivado2017.3 Simulation
Hi @mac004,
Can you please try your design with 2017.4 Vivado version.
Sunilkumar
Observer mac004
Thank you for a reply.
I carried out next activity.
1. Update Vivado 2017.4.
2. Open Project
3. Convert Project. Vivado 2017.3 -> 2017.4
4. Run Post-Synthesis Functional Simulation
 1st, Error
 2nd, No Error
 3rd, Error
 4th, No Error
The result is not good.
ERROR: [XSIM 43-3274] No architecture found for entity DM_CNT_REG. The architecture may be invalidated by recompile of dependent package
I want to solve this problemwhat should I do?
Sincerely,
Hi @mac004,
Can you please share the design files and OS details.
Sunilkumar
Observer mac004
I attach Design File.
Windows 10 Home 64bit
Version 1709
OS build 16299.192
Sincerely,
2018/02/06
 I deleted the file.
Hi @mac004,
I am able to see the issue from my side also. This seems to be the file order issue.
Can you please try removing xsim.dir in simulation directory in each run. Do let me know your findings.
Sunilkumar
Observer mac004
I worked as follows.
1. Deleted the folder.
 DM_CNT_sim.runs
 DM_CNT_sim.cache
 DM_CNT_sim.sim
 DM_CNT_sim.hw
2. Open Project
3. Run Synthesis
 -> Error.
5. Run Post-Synthesis Functional Simulation
 -> No Error.
6. Close Simulation
7. Deleted the folder.
 DM_CNT_sim.sim\sim_1\synth\func\xsim\xsim.dir
8. Run Post-Synthesis Functional Simulation
 -> Error.
The good result was not provided.
Do I make a mistake of any?
Sincerely,
Hi @mac004,
Please try the following
1.Open Project
2. Run Synthesis
3. Run Post-Synthesis Functional Simulation.
4.Delete xsim.dir directory in DM_CNT_sim.sim\sim_1\synth\func\xsim
6.Delete xsim.dir directory in DM_CNT_sim.sim\sim_1\synth\func\xsim
7. Close Simulation
Sunilkumar
Observer mac004
1.Open Project
2. Run Synthesis
 -> Error
 -> Error
7. Run Post-Synthesis Functional Simulation
 -> Error
8.Delete xsim.dir directory in DM_CNT_sim.sim\sim_1\synth\func\xsim
9. Run Post-Synthesis Functional Simulation
 -> Error
10.Delete xsim.dir directory in DM_CNT_sim.sim\sim_1\synth\func\xsim
11. Run Post-Synthesis Functional Simulation
 -> Error
Did you watch a different result?
Sincerely,
Hi @mac004,
This issue present due to multiple entity definitions with the same name in Simulation files.
Entities pulse_ext, pulse_ext_b, pulse_clkupcvt2_b and pulse_clkupcvt2 are exist in multiple files mentioned below
DM_CNT_sim.srcs/sources_1/imports/source/common/comm_lib.vhd
DM_CNT_sim.srcs/sim_1/imports/PTN_CNT/source/common/comm_lib.vhd
DM_CNT_sim.sim/sim_1/synth/func/xsim/DM_CNT_TEST_func_synth.vhd.
Issue been reported to factory.
If we comment above listed entities in files
DM_CNT_sim.srcs/sim_1/imports/PTN_CNT/source/common/comm_lib.vhd simulation will work with out errors.
Sunilkumar
Observer mac004
I am very grateful to have you handle this matter.
I seemed to understand the cause of this issue.
What do I do?
comm_lib.vhd is only one by my design.
And Vivado makes DM_CNT_TEST_func_synth.vhd.
The design which I sent to you is the archive which Vivado made.
Vivado copies comm_lib.vhd.
Should I endure it until Vivado updates it?
Thank you.
Sincerely,
Visitor wio000
I have same error.
I have an error every time I try it.
I use vivado 2018.1.
Is there no solution??
