rseedle
Service request ?
How do I make a Service Request if I didn't go through a reseller ?
I just downloaded the software from the website. How do I get an
active open case number ?
Vivado messege:
ERROR: [Common 17-39] 'launch_simulation' failed due to earlier errors.
Vivado messege detail:
[USF-XSim-62] 'compile' step failed with error(s). Please check the Tcl console output or 'C:/Projects/ArtyAdder2/ArtyAdder2.sim/sim_1/behav/xsim/xvhdl.log' file for more information.
[Vivado 12-4473] Detected error while running simulation. Please correct the issue and retry this operation.
Logfile output:
INFO: [VRFC 10-163] Analyzing VHDL file "C:/Projects/ArtyAdder2/ArtyAdder2.srcs/sources_1/new/Adder4.vhdl" into library xil_defaultlib
ERROR: [VRFC 10-3331] file 'C:/Xilinx/Vivado/2020.1/data/xsim/vhdl/ieee_2008/std_logic_1164.vdb' is probably not a Verific binary database file
ERROR: [VRFC 10-2987] 'std_logic_1164' is not compiled in library 'ieee' [C:/Projects/ArtyAdder2/ArtyAdder2.srcs/sources_1/new/Adder4.vhdl:4]
INFO: [VRFC 10-3107] analyzing entity 'ADDER4'
ERROR: [VRFC 10-2989] 'std_logic_vector' is not declared [C:/Projects/ArtyAdder2/ArtyAdder2.srcs/sources_1/new/Adder4.vhdl:10]
ERROR: [VRFC 10-2989] 'std_logic_vector' is not declared [C:/Projects/ArtyAdder2/ArtyAdder2.srcs/sources_1/new/Adder4.vhdl:11]
ERROR: [VRFC 10-2989] 'std_logic_vector' is not declared [C:/Projects/ArtyAdder2/ArtyAdder2.srcs/sources_1/new/Adder4.vhdl:12]
ERROR: [VRFC 10-2989] 'std_logic' is not declared [C:/Projects/ArtyAdder2/ArtyAdder2.srcs/sources_1/new/Adder4.vhdl:13]
ERROR: [VRFC 10-3782] unit 'adder4' ignored due to previous errors [C:/Projects/ArtyAdder2/ArtyAdder2.srcs/sources_1/new/Adder4.vhdl:8]
INFO: [VRFC 10-3070] VHDL file 'C:/Projects/ArtyAdder2/ArtyAdder2.srcs/sources_1/new/Adder4.vhdl' ignored due to errors
Vivado version 2020.1
The file 'C:/Xilinx/Vivado/2020.1/data/xsim/vhdl/ieee_2008/std_logic_1164.vdb'  is of size zero bytes.
There are multiple files of size zero in my Vivado install.
Any ideas ?
florentw
Hi @rseedle
As per the Service Portal page, the Service Portal (to open SR) is not accessible to all customers
You can get support from the community through the forums.
However you might want to create a new topic with an explicit title if you want to get traction on your topic. Something like:
How do I resolve ERROR: [VRFC 10-2987] 'std_logic_1164' is not compiled in library 'ieee'
Florent
rseedle
Vivado still has the same problems with simulation even after reinstall using a different tar tool.
drjohnsmith
which simulator ?
your problem is you dont have the library needed
