ezygnh
Simulate Behaviour Model Fails in ISE Project Navigator p.20131013
OS: Windows 10 Version 1803 x64
Project Navigator Version:
WxKXEHv
I'm trying to do "Simulate Behaviour Model" in ISE Project Navigator P20131013 for the project attached, but I just get an error.
Behavioural Check Syntax works fine and I can run the simulation on Windows 7 under Virtualbox so I know it is not my project that has a problem.
Here's what I have tried so far
- Uninstalling QT, Codeblocks and MinGW
- Deleting C:\MinGW
- Checking my Environment Variables
- Running sfc /scannow
- Running dism /online /cleanup-image /restorehealth
- Reinstalling Xilinx twice
None of these fix the problem though.
Here is my log from the behavioural model simulation. I've added the flags
-mt off -v 1
in other compiler options too.
Running sch2hdl...
Command Line: sch2hdl -batch {C:/Users/George/Xilinx/Google Drive Storage/Xilinx Projects/MyFirstProject/sch2HdlBatchFile}
Release 14.7 - sch2hdl P.20131013 (nt64)
Copyright (c) 1995-2013 Xilinx, Inc.  All rights reserved.
Started : "Simulate Behavioral Model".
Determining files marked for global include in the design...
Running fuse...
Command Line: fuse -intstyle ise -incremental -lib unisims_ver -lib unimacro_ver -lib xilinxcorelib_ver -lib secureip -o {C:/Users/George/Xilinx/Google Drive Storage/Xilinx Projects/MyFirstProject/AndGate_AndGate_sch_tb_isim_beh.exe} -prj {C:/Users/George/Xilinx/Google Drive Storage/Xilinx Projects/MyFirstProject/AndGate_AndGate_sch_tb_beh.prj} work.AndGate_AndGate_sch_tb work.glbl {-mt off -v 1}
Running: C:\Xilinx\14.7\ISE_DS\ISE\bin\nt64\unwrapped\fuse.exe -intstyle ise -incremental -lib unisims_ver -lib unimacro_ver -lib xilinxcorelib_ver -lib secureip -o C:/Users/George/Xilinx/Google Drive Storage/Xilinx Projects/MyFirstProject/AndGate_AndGate_sch_tb_isim_beh.exe -prj C:/Users/George/Xilinx/Google Drive Storage/Xilinx Projects/MyFirstProject/AndGate_AndGate_sch_tb_beh.prj work.AndGate_AndGate_sch_tb work.glbl -mt off -v 1
ISim P.20131013 (signature 0x7708f090)
Turned off multi-threading for compilation
Determining compilation order of HDL files
The vhdl library search path for library \"std\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/std\"
The veri library search path for library \"std\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/std\"
The vhdl library search path for library \"ieee\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/ieee\"
The veri library search path for library \"ieee\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/ieee\"
The vhdl library search path for library \"ieee_proposed\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/ieee_proposed\"
The veri library search path for library \"ieee_proposed\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/ieee_proposed\"
The vhdl library search path for library \"vl\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/vl\"
The veri library search path for library \"vl\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/vl\"
The vhdl library search path for library \"synopsys\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/synopsys\"
The veri library search path for library \"synopsys\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/synopsys\"
The vhdl library search path for library \"simprim\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/simprim\"
The veri library search path for library \"simprim\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/simprim\"
The vhdl library search path for library \"unisim\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/unisim\"
The veri library search path for library \"unisim\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/unisim\"
The vhdl library search path for library \"unimacro\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/unimacro\"
The veri library search path for library \"unimacro\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/unimacro\"
The vhdl library search path for library \"aim\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/aim\"
The veri library search path for library \"aim\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/aim\"
The vhdl library search path for library \"cpld\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/cpld\"
The veri library search path for library \"cpld\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/cpld\"
The vhdl library search path for library \"pls\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/pls\"
The veri library search path for library \"pls\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/pls\"
The vhdl library search path for library \"xilinxcorelib\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/xilinxcorelib\"
The veri library search path for library \"xilinxcorelib\" is now \"c:/xilinx/14.7/ise_ds/ise/vhdl/hdp/nt64/xilinxcorelib\"
The vhdl library search path for library \"aim_ver\" is now \"c:/xilinx/14.7/ise_ds/ise/verilog/hdp/nt64/aim_ver\"
The veri library search path for library \"aim_ver\" is now \"c:/xilinx/14.7/ise_ds/ise/verilog/hdp/nt64/aim_ver\"
The vhdl library search path for library \"cpld_ver\" is now \"c:/xilinx/14.7/ise_ds/ise/verilog/hdp/nt64/cpld_ver\"
The veri library search path for library \"cpld_ver\" is now \"c:/xilinx/14.7/ise_ds/ise/verilog/hdp/nt64/cpld_ver\"
The vhdl library search path for library \"simprims_ver\" is now \"c:/xilinx/14.7/ise_ds/ise/verilog/hdp/nt64/simprims_ver\"
The veri library search path for library \"simprims_ver\" is now \"c:/xilinx/14.7/ise_ds/ise/verilog/hdp/nt64/simprims_ver\"
The vhdl library search path for library \"unisims_ver\" is now \"c:/xilinx/14.7/ise_ds/ise/verilog/hdp/nt64/unisims_ver\"
The veri library search path for library \"unisims_ver\" is now \"c:/xilinx/14.7/ise_ds/ise/verilog/hdp/nt64/unisims_ver\"
The vhdl library search path for library \"uni9000_ver\" is now \"c:/xilinx/14.7/ise_ds/ise/verilog/hdp/nt64/uni9000_ver\"
The veri library search path for library \"uni9000_ver\" is now \"c:/xilinx/14.7/ise_ds/ise/verilog/hdp/nt64/uni9000_ver\"
The vhdl library search path for library \"unimacro_ver\" is now \"c:/xilinx/14.7/ise_ds/ise/verilog/hdp/nt64/unimacro_ver\"
The veri library search path for library \"unimacro_ver\" is now \"c:/xilinx/14.7/ise_ds/ise/verilog/hdp/nt64/unimacro_ver\"
The vhdl library search path for library \"xilinxcorelib_ver\" is now \"c:/xilinx/14.7/ise_ds/ise/verilog/hdp/nt64/xilinxcorelib_ver\"
The veri library search path for library \"xilinxcorelib_ver\" is now \"c:/xilinx/14.7/ise_ds/ise/verilog/hdp/nt64/xilinxcorelib_ver\"
The vhdl library search path for library \"secureip\" is now \"c:/xilinx/14.7/ise_ds/ise/verilog/hdp/nt64/xip/secureip\"
The veri library search path for library \"secureip\" is now \"c:/xilinx/14.7/ise_ds/ise/verilog/hdp/nt64/xip/secureip\"
The vhdl library search path for library \"work\" is now \"c:/users/george/xilinx/google drive storage/xilinx projects/myfirstproject/isim/work\"
The veri library search path for library \"work\" is now \"c:/users/george/xilinx/google drive storage/xilinx projects/myfirstproject/isim/work\"
-- Dumping Relevant Parameters
XILINX = C:\Xilinx\14.7\ISE_DS\ISE\
PATH = C:\Xilinx\14.7\ISE_DS\ISE\\lib\nt64;C:\Xilinx\14.7\ISE_DS\ISE\\bin\nt64;C:\Xilinx\14.7\ISE_DS\ISE\bin\nt64;C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64;C:\Xilinx\14.7\ISE_DS\ISE\..\..\..\DocNav;C:\Xilinx\14.7\ISE_DS\PlanAhead\bin;C:\Xilinx\14.7\ISE_DS\EDK\bin\nt64;C:\Xilinx\14.7\ISE_DS\EDK\lib\nt64;C:\Xilinx\14.7\ISE_DS\EDK\gnu\microblaze\nt\bin;C:\Xilinx\14.7\ISE_DS\EDK\gnu\powerpc-eabi\nt\bin;C:\Xilinx\14.7\ISE_DS\EDK\gnuwin\bin;C:\Xilinx\14.7\ISE_DS\EDK\gnu\arm\nt\bin;C:\Xilinx\14.7\ISE_DS\EDK\gn
u\microblaze\linux_toolchain\nt64_be\bin;C:\Xilinx\14.7\ISE_DS\EDK\gnu\microblaze\linux_toolchain\nt64_le\bin;C:\Xilinx\14.7\ISE_DS\common\bin\nt64;C:\Xilinx\14.7\ISE_DS\common\lib\nt64;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Program Files (x86)\Python 2.7\;C:\Program Files (x86)\Python 2.7\Scripts;C:\ProgramData\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\PuTTY\;C:\Program Files (x86
)\OpenCV\build\bin;C:\Program Files\Microsoft Network Monitor 3\;C:\Program Files (x86)\QuickTime\QTSystem\;C:\Program Files\nodejs\;C:\Program Files\adb;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files\Git\cmd;C:\Program Files\Crucial\Crucial Storage Executive;C:\Program Files\MATLAB\bin;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Users\George\AppData\Roaming\Ruby25\bin;C:\Users\George\AppData\Local\Microsoft\Win
dowsApps;C:\Program Files (x86)\ADB\;C:\Program Files\Fiddler;C:\Users\George\AppData\Roaming\npm;D:\;C:\Users\George\AppData\Local\GitHubDesktop\bin;C:\Program Files (x86)\mitmproxy\bin;C:\Program Files (x86)\SSH Communications Security\SSH Secure Shell
CWD = C:/Users/George/Xilinx/Google Drive Storage/Xilinx Projects/MyFirstProject
GCC = C:/Xilinx/14.7/ISE_DS/ISE/gnu/MinGW/Beta/nt64/bin/x86_64-w64-mingw32-gcc.exe
-- Done dumping Relevant Parameters
-- Dumping System Information
release = 6.2
machine = x86_64
-- Done dumping System Information
-- Dumping Loaded Modules
C:\WINDOWS\SYSTEM32\MPR.dll
C:\WINDOWS\SYSTEM32\WSOCK32.dll
C:\WINDOWS\SYSTEM32\apphelp.dll
C:\WINDOWS\SYSTEM32\cscapi.dll
C:\WINDOWS\SYSTEM32\dbghelp.dll
C:\WINDOWS\SYSTEM32\ntdll.dll
C:\WINDOWS\System32\ADVAPI32.dll
C:\WINDOWS\System32\DAVHLPR.dll
C:\WINDOWS\System32\GDI32.dll
C:\WINDOWS\System32\IMM32.DLL
C:\WINDOWS\System32\KERNEL32.DLL
C:\WINDOWS\System32\KERNELBASE.dll
C:\WINDOWS\System32\PSAPI.DLL
C:\WINDOWS\System32\RPCRT4.dll
C:\WINDOWS\System32\SspiCli.dll
C:\WINDOWS\System32\USER32.dll
C:\WINDOWS\System32\WINSTA.dll
C:\WINDOWS\System32\WS2_32.dll
C:\WINDOWS\System32\bcrypt.dll
C:\WINDOWS\System32\bcryptPrimitives.dll
C:\WINDOWS\System32\combase.dll
C:\WINDOWS\System32\davclnt.dll
C:\WINDOWS\System32\drprov.dll
C:\WINDOWS\System32\gdi32full.dll
C:\WINDOWS\System32\msvcp_win.dll
C:\WINDOWS\System32\msvcrt.dll
C:\WINDOWS\System32\netutils.dll
C:\WINDOWS\System32\nfsnp.dll
C:\WINDOWS\System32\ntlanman.dll
C:\WINDOWS\System32\ole32.dll
C:\WINDOWS\System32\sechost.dll
C:\WINDOWS\System32\ucrtbase.dll
C:\WINDOWS\System32\win32u.dll
C:\WINDOWS\System32\wkscli.dll
C:\WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9415_none_08e0c10ba840a28a\MSVCP90.dll
C:\WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9415_none_08e0c10ba840a28a\MSVCR90.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\LIBBZ2.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\boost_date_time-vc90-mt-p-1_38.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\boost_filesystem-vc90-mt-p-1_38.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\boost_iostreams-vc90-mt-p-1_38.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\boost_program_options-vc90-mt-p-1_38.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\boost_regex-vc90-mt-p-1_38.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\boost_system-vc90-mt-p-1_38.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\boost_thread-vc90-mt-p-1_38.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\boost_zlib-vc90-mt-p-1_38.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\libICR.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\libMiniZip.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\libPersonalityModule.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\libPort_Std.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\libPortability.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\libPrjrep_Clientac.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\libStaticFileParsers.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\libThread.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\libUtilC_MessageDispatcher.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\libUtilities.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\libVrfc_Verific.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\libVrfc_Vhdl_Sort.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\libZlib.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\libisl_iostreams.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\libpthread.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\libxercesc.dll
C:\Xilinx\14.7\ISE_DS\ISE\lib\nt64\stlport.5.1.dll
-- Done dumping Loaded ModuWARNING:HDLCompiler:746 - "N:/P.20131013/rtf/vhdl/src/ieee/numeric_std.vhd" Line 878: Range is empty (null range)les
-- Dumping library mapping
aim=C:/Xilinx/14.7/ISE_DS/ISE/vhdl/hdp/nt64/aim
aim_ver=C:/Xilinx/14.7/ISE_DS/ISE/verilog/hdp/nt64/aim_ver
cpld=C:/Xilinx/14.7/ISE_DS/ISE/vhdl/hdp/nt64/cpld
cpld_ver=C:/Xilinx/14.7/ISE_DS/ISE/verilog/hdp/nt64/cpld_ver
ieee=C:/Xilinx/14.7/ISE_DS/ISE/vhdl/hdp/nt64/ieee
ieee_proposed=C:/Xilinx/14.7/ISE_DS/ISE/vhdl/hdp/nt64/ieee_proposed
pls=C:/Xilinx/14.7/ISE_DS/ISE/vhdl/hdp/nt64/pls
secureip=C:/Xilinx/14.7/ISE_DS/ISE/verilog/hdp/nt64/xip/secureip
simprim=C:/Xilinx/14.7/ISE_DS/ISE/vhdl/hdp/nt64/simprim
simprims_ver=C:/Xilinx/14.7/ISE_DS/ISE/verilog/hdp/nt64/simprims_ver
std=C:/Xilinx/14.7/ISE_DS/ISE/vhdl/hdp/nt64/std
synopsys=C:/Xilinx/14.7/ISE_DS/ISE/vhdl/hdp/nt64/synopsys
uni9000_ver=C:/Xilinx/14.7/ISE_DS/ISE/verilog/hdp/nt64/uni9000_ver
unimacro=C:/Xilinx/14.7/ISE_DS/ISE/vhdl/hdp/nt64/unimacro
unimacro_ver=C:/Xilinx/14.7/ISE_DS/ISE/verilog/hdp/nt64/unimacro_ver
unisim=C:/Xilinx/14.7/ISE_DS/ISE/vhdl/hdp/nt64/unisim
unisims_ver=C:/Xilinx/14.7/ISE_DS/ISE/verilog
WARNING:HDLCompiler:746 - "N:/P.20131013/rtf/vhdl/src/ieee/numeric_std.vhd" Line 879: Range is empty (null range)
FATAL_ERROR:Simulator:Fuse.cpp:500:1.133 - Failed to compile generated C file isim/AndGate_AndGate_sch_tb_isim_beh.exe.sim/work/m_00000000004134447467_2073120511.c   For technical support on this issue, please visit http://www.xilinx.com/support.
vl=C:/Xilinx/14.7/ISE_DS/ISE/vhdl/hdp/nt64/vl
work=isim/work
xilinxcorelib=C:/Xilinx/14.7/ISE_DS/ISE/vhdl/hdp/nt64/xilinxcorelib
xilinxcorelib_ver=C:/Xilinx/14.7/ISE_DS/ISE/verilog/hdp/nt64/xilinxcorelib_ver
-- Done dumping library mapping
Analyzing Verilog file "C:/Users/George/Xilinx/Google Drive Storage/Xilinx Projects/MyFirstProject/AndGate.vf" into library work
Parsing module <AndGate>.
Analyzing Verilog file "C:/Xilinx/14.7/ISE_DS/ISE//verilog/src/glbl.v" into library work
Parsing module <glbl>.
Parsing VHDL file "C:/Users/George/Xilinx/Google Drive Storage/Xilinx Projects/MyFirstProject/TestBench.vhd" into library work
Parsing entity <AndGate_AndGate_sch_tb>.
Parsing architecture <behavioral> of entity <andgate_andgate_sch_tb>.
Starting static elaboration
Elaborating module <glbl>.
Executing AndGate_AndGate_sch_tb(behavioral)
Going to verilog side to elaborate module AndGate
Elaborating module <AndGate>.
Back to vhdl to continue elaboration
Completed static elaboration
Compiling module glbl - m_00000000004134447467_2073120511
ICR Memory Use: 40424 bytes
Compiling isim/AndGate_AndGate_sch_tb_isim_beh.exe.sim/work/m_00000000004134447467_2073120511.c to isim/AndGate_AndGate_sch_tb_isim_beh.exe.sim/work/m_00000000004134447467_2073120511.nt64.obj with command:
"C:/Xilinx/14.7/ISE_DS/ISE/gnu/MinGW/Beta/nt64/bin/x86_64-w64-mingw32-gcc.exe" -Wa,-W  -O  -c -o "isim/AndGate_AndGate_sch_tb_isim_beh.exe.sim/work/m_00000000004134447467_2073120511.nt64.obj" -I"C:/Xilinx/14.7/ISE_DS/ISE/data/include" "isim/AndGate_AndGate_sch_tb_isim_beh.exe.sim/work/m_00000000004134447467_2073120511.c"
Process "Simulate Behavioral Model" failed
I'm really at a loss of what to do, I need Xilinx to work for university. Can anyone please help?
shameera
Hi @ezygnh,
I think it might be something related to your setup/environment as I am able to simulate the shared design without any issues at my end.
You can check the same by simulating the design if you have access to any other machine.
dpaul24
@ezygnh,
Win 10 is not among the recommended OSes for ISE.
See this AR : https://www.xilinx.com/support/answers/18419.html
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
ezygnh
I've simulated the design in Windows 7 under virtualbox and it runs fine, thanks for confirming this
ezygnh
I know that Xilinx isn't officially supported on windows 10, but there are many workarounds to enable the software on windows 10. I don't want to downgrade my OS just to get Xilinx working.
ezygnh
Anyone? :(
bandi
Hi @ezygnh ,
Can you please check if the below AR helps:
https://www.xilinx.com/support/answers/62380.html
Please note "Xilinx does not officially support using Windows 8.1 or Windows 10 with ISE Design Suite".
Thanks & Regards,
Sravanthi B
