03-20-2018 10:42 AM - edited 03-20-2018 10:46 AM
I'm working on a project which uses the AXI Stream VIP IP using the Vivado 2017.2 simulator. I created an example test bench by doing the following:
import axi4stream_vip_v1_0_1_pkg::*;
import design_1_axi4stream_vip_0_1_pkg::*;
I run the simulation and it fails. Here are the logs:
ERROR: [VRFC 10-91] axi4stream_v1_0_1_pkg is not declared
ERROR: [VRFC 10-91] design_1_axi4stream_vip_0_1_pkg is not declared
I get the same error with the axi_vip_pkg. I tried using the example project for the axi4stream VIP core, but this fails with the same error.
I found a similar issue with the live syntax checker: https://forums.xilinx.com/t5/Simulation-and-Verification/axi-vip-package-not-declared-issue/m-p/839789#U839789
But according to the answer, the simulator should work fine, which it isn't in my case...
03-26-2018 04:46 AM
Hi @farhadyusufali,
I created a small test block design using the AXI4 Stream VIP and ran the simulation without seeing the issue.
Can you provide a test case that replicates the issue?
Best Regards
Aidan
02-05-2019 12:29 AM
I had similar issue. The problem was (for me) that the naming of the imported and the declared package does not matched. (In some cases Vivado renames it Because reasons.)
