Simulation error
My simulator errors on the red lettered locations.  Does anyone have an idea what I need to do.
Perhaps it needs to point to a library?
Thank you,
  Gary
This is code from xapp1014..  file kcpsm3_edh.v
genvar spm_index;
generate
    if (KCPSM_SPM_SIZE <= 16)
        for (spm_index=0; spm_index < 8; spm_index = spm_index + 1)
            begin : spmbit
                 // synthesis translate_off
                 defparam spmbit[spm_index].memory_bit.INIT = 16'h0000;
                 // synthesis translate_on
                 RAM16X1S memory_bit (
                 .D(sx[spm_index]),
                 .WE(memory_enable),
                 .WCLK(clk),
                 .A0(second_operand[0]),
                 .A1(second_operand[1]),
                 .A2(second_operand[2]),
                 .A3(second_operand[3]),
                 .O(memory_data[spm_index]))/* synthesis xc_props = "INIT=0000"*/;
                 FD store_flop (
                 .D(memory_data[spm_index]),
                 .Q(store_data[spm_index]),
                 .C(clk));
            end
    else if (KCPSM_SPM_SIZE <= 32)
            begin : spmbit
                 defparam spmbit[spm_index].memory_bit.INIT = 32'h00000000;
                 RAM32X1S memory_bit (
                 .D(sx[spm_index]),
                 .WE(memory_enable),
                 .WCLK(clk),
                 .A4(second_operand[4]),
                 .O(memory_data[spm_index]))/* synthesis xc_props = "INIT=00000000"*/;
                 FD store_flop (
                 .C(clk));
            end
    else
            begin : spmbit
                 defparam spmbit[spm_index].memory_bit.INIT = 64'h0000000000000000;
                 RAM64X1S memory_bit (
                 .D(sx[spm_index]),
                 .WE(memory_enable),
                 .WCLK(clk),
                 .A5(second_operand[5]),
                 .O(memory_data[spm_index]))/* synthesis xc_props = "INIT=0000000000000000"*/;
                 FD store_flop (
                 .C(clk));
            end
endgenerate
alog -O2 -l secureip -l unisims_ver -sve  -work VR_SDI_JUN22B $dsn/src/kcpsm3_edh.v
# Warning: The source is compiled without the -dbg switch. Line breakpoints and code coverage will not be available.
# Compile...
# Pass 1. Scanning modules hierarchy.
# Info: VCP2113 Module \$root found in current working library.
# Error: VCP7270 kcpsm3_edh.v : (1553, 72): Generate item 'spmbit[spm_index].memory_bit.INIT' cannot be found.
# Error: VCP7270 kcpsm3_edh.v : (1574, 76): Generate item 'spmbit[spm_index].memory_bit.INIT' cannot be found.
# Error: VCP7270 kcpsm3_edh.v : (1596, 84): Generate item 'spmbit[spm_index].memory_bit.INIT' cannot be found.
# Info: VCP2110 Module FDS found in library unisims_ver.
Professor
Professor
Re: Simulation error
It looks like your simulator may be having a problem with the hierarchical name in this
case.  What simulator are you using?  Perhaps it doesn't construct the module hierarchy
name from the generate process name the same way as the simulator used by the creator
of this code.
One workaround is to change the instantiations to Verilog 2001 style like:
RAM16X1S
  .INIT  (16'h0000)
memory_bit (
                 .D(sx[spm_index]),
etc.
and leave out the defparam statements.
-- Gabor
-- Gabor
Thank You Gabor
