Simulator Not Starting
I have been working on a simple testbench project, and I have now rebuilt the entire project a second time thiking I had corrupted it somehow, and am getting the exact same error messages as the last time. The first three or so times, the simulator starts perfectly, then after that I always get the same error that the "Simulation Engine failed to start". I understand this is a generic message, but the only preceeding error is absolutely unintelligible to me:
"Could not open the HDL type file std::endl"
This does not make any sense to me. The entire relevant section of TCL Console output is below:
****** Webtalk v2015.2 (64-bit)
**** SW Build 1266856 on Fri Jun 26 16:35:25 MDT 2015
**** IP Build 1264090 on Wed Jun 24 14:22:01 MDT 2015
** Copyright 1986-2015 Xilinx, Inc. All Rights Reserved.
source U:/Thesis_Vivado/Test_Projects/Test_AD9629_Interface/Test_AD9629_Interface.sim/sim_1/behav/xsim.dir/AD9629_Interface_TB_behav/webtalk/xsim_webtalk.tcl -notrace
while executing
"webtalk_transmit -clientid 3649467013 -regid "208714772_0_0_040" -xml U:/Thesis_Vivado/Test_Projects/Test_AD9629_Interface/Test_AD9629_Interface.sim/s..."
(file "U:/Thesis_Vivado/Test_Projects/Test_AD9629_Interface/Test_AD9629_Interface.sim/sim_1/behav/xsim.dir/AD9629_Interface_TB_behav/webtalk/xsim_webtalk.tcl" line 41)
INFO: [Common 17-206] Exiting Webtalk at Thu Sep 17 16:56:23 2015...
run_program: Time (s): cpu = 00:00:00 ; elapsed = 00:00:14 . Memory (MB): peak = 692.816 ; gain = 0.000
INFO: [USF-XSim-4] XSim::Simulate design
INFO: [USF-XSim-61] Executing 'SIMULATE' step in 'U:/Thesis_Vivado/Test_Projects/Test_AD9629_Interface/Test_AD9629_Interface.sim/sim_1/behav'
INFO: [USF-XSim-98] *** Running xsim
with args "AD9629_Interface_TB_behav -key {Behavioral:sim_1:Functional:AD9629_Interface_TB} -tclbatch {AD9629_Interface_TB.tcl} -view {U:/Thesis_Vivado/Test_Projects/Test_AD9629_Interface/AD9629_Interface_TB_behav.wcfg} -log {simulate.log}"
INFO: [USF-XSim-8] Loading simulator feature
Vivado Simulator 2015.2
ERROR: [Simtcl 6-50] Simulation engine failed to start: The Simulation shut down unexpectedly during initialization.
Please see the Tcl Console or the Messages for details.
Thanks for any help!
Brian
Re: Simulator Not Starting
Hi @brianvg
Can you share the test case project with us?
Bharath
Please mark the Answer as "Accept as solution" if information provided addresses your query/concern.
Try to create a new project and move the files to run simulation. Looks to be a project corruption issue. I hope you are using a supported OS.
Debraj
