Simulator with DSP Element stops at 0 fs
Hi there,
to get more familiar with the Zynq and VHDL I try to get more into the usage of DSP slices. I created an entity which accepts N in and outputs (all of type std_logic_vector) which applies a multiplication to a selected signal. The DSP macro is from the language template and adapted to the situation.
Sadly the Vivado2017.2 simulator is stuck at 0fs simulation time. The build is successful.
Here is the code of my entity
library ieee;
use ieee.STD_LOGIC_1164.ALL;
package multipledata is
    constant NATURAL_BUS_WIDTH : integer := 2;
    constant NATURAL_DATA_WIDTH : integer := 2;
    type data is array(natural range <>) of std_logic_vector(NATURAL_DATA_WIDTH-1 downto 0);
end package;
library ieee;
use ieee.numeric_std.all;
Library UNISIM;
use UNISIM.vcomponents.all;
Library UNIMACRO;
use UNIMACRO.vcomponents.all;
use work.multipledata.all;
entity demultiplexer_dsp is
    generic( bus_width : integer := NATURAL_BUS_WIDTH;
            data_width : integer := NATURAL_DATA_WIDTH);
    port(
        i : in data(bus_width-1 downto 0);
        factor : in std_logic_vector(data_width-1 downto 0);
        clock : in std_logic;
        clock_enable : in std_logic;
        selection : in integer range 0 to bus_width;
        o : out data(bus_width-1 downto 0));
end demultiplexer_dsp;
architecture Behavioral of demultiplexer_dsp is
    signal reset : std_logic := '0';
    signal a : std_logic_vector(data_width-1 downto 0) ;
    signal p : std_logic_vector(2*data_width-1 downto 0) ;
    constant dsp_latency : integer := 3;
begin
MULT_MACRO_inst : MULT_MACRO
   generic map (
      DEVICE => "7SERIES",    -- Target Device: "VIRTEX5", "7SERIES", "SPARTAN6"
      LATENCY => dsp_latency,           -- Desired clock cycle latency, 0-4
      WIDTH_A => data_width,          -- Multiplier A-input bus width, 1-25
      WIDTH_B => data_width)          -- Multiplier B-input bus width, 1-18
   port map (
      P => P,     -- Multiplier ouput bus, width determined by WIDTH_P generic
      A => A,     -- Multiplier input A bus, width determined by WIDTH_A generic
      B => factor,     -- Multiplier input B bus, width determined by WIDTH_B generic
      CE => clock_enable,   -- 1-bit active high input clock enable
      CLK => clock, -- 1-bit positive edge clock input
      RST => reset  -- 1-bit input active high reset
   -- End of MULT_MACRO_inst instantiation
   process(selection)
    variable wait_for_dsp : integer := dsp_latency;
    variable index : integer := 0;
   begin
   if(selection'event) then
    a <= i(index);
    reset <= '0';
    wait_for_dsp := dsp_latency;
   end if;
    for index in 0 to bus_width-1 loop
        if(index = selection and wait_for_dsp <= 0) then
            o(index) <= p(data_width-1 downto 0);
            reset <= '1';
        else
            o(index) <= i(index);
        end if;
        wait_for_dsp := wait_for_dsp - 1;
    end loop;
   end process;
end Behavioral;
To test the whole thing I created the following testbench
library ieee;
Library UNISIM;
Library UNIMACRO;
entity demux_mult_tb is
end demux_mult_tb;
architecture behavioral of demux_mult_tb is
    constant b_width : integer := 2;
    constant d_width : integer := 2;
    component demultiplexer_dsp is
    generic( bus_width : integer;
            data_width : integer);
    port(
    end component;
    signal i_tb : data(b_width-1 downto 0);
    signal factor_tb : std_logic_vector(d_width-1 downto 0);
    signal clock_tb : std_logic;
    signal ce   : std_logic;
    signal sel_tb : integer := 0;
    signal o_tb : data(b_width-1 downto 0);
begin
mapping: demultiplexer_dsp
    generic map(bus_width => b_width, data_width => d_width)
    port map(
                i => i_tb,
                factor => factor_tb,
                clock => clock_tb,
                clock_enable => ce,
                selection => sel_tb,
                o => o_tb
    process
        variable step : integer := 0;
    begin
        for index in 0 to b_width-1 loop
            i_tb(index) <= std_logic_vector(to_unsigned(0, i_tb(index)'length));
        end loop;
        factor_tb <= std_logic_vector(to_unsigned(0, factor_tb'length));
        clock_tb <= '0';
        ce <= '0';
        for step in 0 to 10 loop
                i_tb(index) <= std_logic_vector(to_unsigned(step, i_tb(index)'length));
            end loop;
            -- start the calculation at step 4!
            if(step = 4) then
                sel_tb <= 1;
            end if;
            clock_tb <= clock_tb xor '1';
        end loop;
    end process;
end behavioral;
Are there any mistakes I made or is it a problem of the simulator?
By the way: I'm not so much familiar with the VHDL code, therefore it migh be a little messy ;)
Re: Simulator with DSP Element stops at 0 fs
Hi @tmaintz,
You haven't included any delays / wait statements into your testbench.
Try the code attached and see how you get on.
Let me know if this helps.
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
Hi @tmaintz,
Best Regards
Aidan
Thanks! That helped. Now I can debug my code ;)
