[SystemVerilog] Array Declaration cases
Hi All,
Is there a difference in the following declarations:
case1:
reg [3:0][7:0] abc;
case2:
reg [3:0] abc [7:0];
case3:
reg abc [3:0][7:0];
What's the difference?
Thank you!
Re: [SystemVerilog] Array Declaration cases
Hi @dmitryl_home,
case1: reg [3:0][7:0] abc;
The above declaration represents a Packed array and the above declaration treats the 32 bits present in the array as 4 groups of 8 bits each. In memory all these bits are packed together as 32 bits.
case2: reg [3:0] abc [7:0];
This sort of declaration generally represents an unpacked array and the above declaration treats the 32 bits present in the array as 8 groups of 4 bits each. In memory these arrays are stored using regular addressing rather than packed together in a single address.
case3: reg abc [3:0][7:0];
Which in general is a multi dimension array.
Thanks & Regards,
A.Shameer
