SystemVerilog in Vivado
Are there plans to support any of the non-synthesisable features of SystemVerilog in the upcoming Vivado releases?
Will Vivado Simulator only ever support the synthesisable constructs of SV?
Vivado simulator currently support all synthesizable construct. Regarding non-synthesizable contruct, can you please let us know what kind of contruct you are looking for? For support plan in vivado simulator related with non-synthesizable construct, I will request you to drop a mail to mosess@xilinx.com. He is marketing manager for vivado simulator.
--dhiRAj
--dhiRAj
I was after covergroups in particular. I get the error:
[XSIM 43-3980] Line 9 : The "System Verilog Covergroup" is not supported yet for simulation.
Currently, the constructs that are supported in Vivado are given inpage 176 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_2/ug900-vivado-logic-simulation.pdf
How ever coverage support is under road map.
Thanks,Vijay
Hi @tomkulaga
Hope you got the information you are looking for.
Please close the thread by marking the solution.
Thanks,Vijay
