Test bench inputs large circuit testing
I want to test a combinational circuit with 36 inputs for all possible input combinations. I have written a for loop in the testbench, but apparently the loop variable is only allowed to be 32 bits (int) even though I explicitly declare it as a reg of 36 bits. I am using Xilinx ISE 9.2i simulator ISIM for the simulations.
Is it possible to test for this many possible inputs? Please advice.
I really appreciate your inputs and wait in anticipation.
Rizwan
2^36 is a big number  68,719,476,736 to be exact.  If your simulation can get 100,000 vectors/sec it would take 7.95 days to complete.
If you still want to go ahead and do this then I would suggest that you use two loops.  The inner loop covers bits 0-31 (0 to 4,294,967,295) and the outer loop covers the last 4 bits of 32-35 (0 to 15).
Hi Rizwan,
that will be a looooong simulation.
How about not using loops.
use ieee.numeric_std.all;
signal count36 : unsigned(35 downto 0) := (others => '0');  -- initialize 36 bit vector to zero
process
  count36<= count36 + 1;
  wait for 100ns;
end process;
then you can assignit e.g like this:
  DUT_In <= std_logic_vector(count36);
or put it in the port map of the DUT instanciation.
Have a nice simulation
   Eilert
