Timing or Post-route incorrect simulation result.
Dear all,
I am having problem in Timing simulation (post-route simulation). I have pasted the relevant items below.
I am having the following warning and I guess because of this I am not able to get the required results. It will be really helpful if some one can decode
this warning, i.e. what is $setuphold and things in bracket. Well I have concepts regarding setup and hold time but I cannot understand what the error here means
WARNING: at 118166 ps: Timing violation in /stim_count/uut/out_2/ $setuphold( CLK:118166 ps, I:117651 ps,536 ps,-344 ps)
My design is a simple counter as follows
Code:
module signed_counter(
    input clk,
    input rst,
    input signed [7:0] num1,
    input signed [7:0] num2,
    output reg [8:0] out
always@(posedge clk)
begin
	if(rst) out <=9'b0;
	else  out <= num1 + num2;
end
endmodule
the simulation file is as follows
Code:
`timescale 1ns / 1ns
module stim_count;
	// Inputs
	reg clk;
	reg rst;
	reg [7:0] num1;
	reg [7:0] num2;
	// Outputs
	wire [8:0] out;
	// Instantiate the Unit Under Test (UUT)
	signed_counter uut (
		.clk(clk), 	.rst(rst),
		.num1(num1), .num2(num2),
		.out(out)
	initial begin
		// Initialize Inputs
		clk = 0;
		rst = 1;
		num1 = -100;		num2 = -7;
		# 15 rst=1'b0;
#25	num1 = -100;		num2 = -7;
#25	num1 = -100;		num2 = -128;
#25	num1 =  127;		num2 = 127;
#25	num1 =  108;		num2 = 119;
#15	num1 = -128;		num2 = -128;
	end
		always #5 clk = ~clk;
endmodule
The resulting waveform is here.
Re: Timing or Post-route incorrect simulation result.
The warning suggests that timing violation is detected for instance "/stim_count/uut/out_2".
You can check SDF file, search the instance and see the required $setuphold value for the I input with regards to CLK.
I think 536 ps is the expected setup value while observed value is 515 ps (118166 - 117651).
Have you specify PERIOD constraint in UCF? We recommend that you do post-PAR static timing analysis for sign-off.
