Unimacros not showing up in simulation?
I have always liked unimacros since they allow to easily instantiate simple primitives without any other files (XCI, etc).
However, when I instantiate a unimacro in my design (the BRAM_TDP_MACRO to be precise) the instance does not show up on my simulation hierarchy in the "Scope" tab in Vivado.
I thought it might have to do with the fact that I have a mix of SystemVerilog-VHDL in my design, however I placed the instance on the top-level of the hierarchy and still nothing.. everything else is there, but the bram that should be instantiated with the unimacro is not...
Is this just me? Is this a known-issue?
Re: Unimacros not showing up in simulation?
hi @arquer
Check similar issue. Hope this helps:
https://forums.xilinx.com/t5/Simulation-and-Verification/bram-tdp-marco-missing-when-instantiated-in-Vivado/td-p/511083
Rohit
Rohit
Voyager
Voyager
Hey @arquer,
Are you sure that the BRAM didn't just get removed (optimized away) by the tools?
You might want to place a DONT_TOUCH on it or at least a MARK_DEBUG on relevant networks.
Best,
Herbert
-------------- Yes, I do this for fun!
I am sure that is not the case because I actually see the signals comming from the BRAM changing...
Full disclousure:
1. The BRAM is inside a generate loop
2. The BRAM is instantiated in Verilog but upper levels of the hierarchy are VHDL
hi @arquer
Rohit
Rohit
Thanks @thakurr
using the "--debug all" option during elaboration solved the issue. I have to say simulation is much slower now though, but I guess everything comes at a price..
