Using modports in Vivado
I am using SystemVerilog interfaces/modports to simplify module connection logic. Here is a snippet of my source file.
I have an interface (called `axi4lite`) with two modports defined: `master` and `slave`. When I instantiate them into my logic, I have something as follows:
axi4lite axi_master();
Module1 DUT1 (
  .axi_aclk (axi_master.master.axi_aclk)
Module2 DUT2 (
  .axi_aclk (axi_master.slave.axi_aclk)
Running through simulation, I get the following warnings:
WARNING: [VRFC 10-2681] modport master should not be used in hierarchical reference [/home/antonio/fpga/GlueBoard/src/axi4/example/axi4_csr_example.v:127]
WARNING: [VRFC 10-2681] modport slave should not be used in hierarchical reference [/home/antonio/fpga/GlueBoard/src/axi4/example/axi4_csr_example.v:264]
I can't find any documentation for these warnings. Can you please describe what this warning means, and what is the preferred coding style? Are these language features synthesizable?
Antonio
Hi @antoniopug,
I think for modports hierarchical referencing is not supported , as the warning is says. Modports are only used in interface port and virtual interface declarations. They are not used to reference individual interface items.
Please check this AR# for System Verilog support:
https://www.xilinx.com/support/answers/51837.html
Hope the provided information will be helpful.
Raj
Hi @antoniopug,
Raj
Thanks, using that coding style resolved this issue.
Hi @antoniopug,
If you query is resoved, please close this thread by marking it as accepted solution.
Raj.
