ronnu
Using predefined attributes
Hello
I have a simple question about VHDL. Are the predefined attributes usable only in sequential statements?
I had a simple excercise which involved using the attribute T'pos(x) in both sequential and concurrents tatements. In sequential statement it works fine, but I couldn't get it to work in a concurrnet statement. See my example below (from Peter Asheden's book).
Exercise with sequential statement which works fine:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity charecter_evaluator is
	port (
			char : in character;
			character_class : out integer range 0 to 4
end charecter_evaluator;
architecture Behavioral of charecter_evaluator is
begin
	char_eval : process (char) is
		variable v_char : integer := 0;
		variable v_character_class : integer range 0 to 4 :=0;
	begin
		v_char := character'pos(char);
		case v_char is
			when 65 to 90 | 97 to 122 =>
				v_character_class := 1;
			when 48 to 58 =>
				v_character_class := 2;
			when 32 to 47 | 59 to 64 | 91 to 96 | 123 to 126 | 128 to character'pos(character'right) =>
				v_character_class := 3;
			when 0 to 31 | 127 =>
				v_character_class := 4;
			when others =>
				v_character_class := 0;
		end case;
		character_class <= v_character_class;
	end process char_eval;
end Behavioral;
Excercise with concurrent statements (select variable assignment) which doesn't give the position number of the character:
library IEEE;
entity character_evaluator_concurrent is
    Port ( char : in  character;
           character_class : out integer range 0 to 4);
end character_evaluator_concurrent;
architecture Behavioral of character_evaluator_concurrent is
	signal v_char : integer :=0;
begin
	v_char <= character'pos(char);
	with v_char select
		character_class <= 1 when 65 to 90 | 97 to 122,
								 2 when 48 to 58,
								 3 when 32 to 47 | 59 to 64 | 91 to 96 | 123 to 126 | 128 to character'pos(character'right),
								 4 when 0 to 31 | 127,
								 0 when others;
end Behavioral;
 But when I include the attribute usage into a sequential statement it works fine:
library IEEE;
begin
	process (char)
	begin
	v_char <= character'pos(char);		-- attributes can only be used in sequential statements??
	end process;
	with v_char select
								 2 when 48 to 58,
								 0 when others;
end Behavioral;
To me it seems that attributes can only be used with sequential statements, but maybe I am missing something. Couldn't find the answer from Asheden's book so maybe someone here can answer.
geoffbarnes
Is this vivado sim?    Attributes should be ok with concurrent statements, so this could be a bug.
In your example, the character'pos(char)  has to evaluate at run-time when the argument changes - just like a concurrent function call.   The tool has to create an equivalent process and make sure the function arguments form the sensitivity list.
As far as I know "run-time" concurrent attributes (and functions) are valid in VHDL.  A quick test  in Modelsim seems to work - however it wouldn't hurt to check the standard or Ashenden.
Your example used another concurrent attribute , character'pos(character'right).   This worked as expected?   In this case the attribute is evaluated only at elaboration time - so it's effectively a constant.
ronnu
No, it's iSIM.
The other attribute works fine, but as you said, it is only evaluated at the beginning, so little bit different.
geoffbarnes
A workaround might be to wrap the attribute call in a function...  assuming isim implemented concurrent function calls correctly.
