efrpass
VHDL Behavioral vs Post-Route
I'm having an issue with my project.
I implemented a counter of rising edges that each 10 shots should give a signal and after other 10 a new one.
Now the behavioral simulation it went well while in the post-rout I've an issue with clock.
Are there any requirements or precaution to be taken for the post-route simulation? How I can handle the clock to have a good result in the post-route too?
Maybe I provide few details but I don't post the code since I hope that the issue is not there.
Thanks in advance
drjohnsmith
source code ?
Simulation clock frequency
   simulation resolution
picture of simulation output,
basically a bit more information might give us a hand
vijayak
Hi @efrpass
Can you provide details on the issue you are seeing? May be the waveform comparison (Behavioral Vs  Post-Route) which shows the expected results.
Check the synthesis and implementation log files to see if any of the logic getting trimmed causing this issue.
Thanks,Vijay
