VHDL testbench's stimuli convention?
Hi, I am famailiar with verilog and new to vhdl.
I recently purchased a third party's solution that includes vhdl design files and vhdl testbench.
The snapshot above shows my simulation files.
In tb_fmc216.vhd, it has module instantiation and clock generation. But I don't see how input.txt is read from the testbench.
I wonder if there's some convention in vhdl testbench that reads input.txt and generates output.txt.
Thanks in advance.
Re: VHDL testbench's stimuli convention?
without seeing the files, my crystal ball is in overtime
Its common for test benches to read stimuli,
that way many tests can be run using one test bench,
this shows such an example
https://www.nandland.com/vhdl/examples/example-file-io.html
Hi @moon5756 ,
I am not clear on the exact question here, as input.txt has been added to the project files it will be available to the testbench if it is referenced.
If you are using a scripted flow you will either have to include it in the same directory or provide the path to the text file.
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
