alfamanager
[VRFC 10-3429] illegal recursive instantiation Error!
Hi!
I try to simulate Fifo Generator 13.2 with AXI interfacing.
When I try to simulate, program gaves me "[VRFC 10-3429] illegal recursive instantiation of 'fifo_axi_default(behavioral)' ["C:/Users/ITOPYA/Desktop/fifo_axi/fifo_axi.srcs/sources_1/new/fifo_axi.vhd":49]" error.
How can I solve this can you help me please?
miti
@alfamanager ,
In file "fifo_axi.txt" , please remove the instantiation of entity "fifo_axi", it causes error for recursive instantiation.
dpaul24
@alfamanager ,
I think you are doing something wrong in the FIFO generation process (I don't see some basic FIFO signals in the instantiation).
First Q - did you read the document https://www.xilinx.com/support/documentation/ip_documentation/fifo_generator/v13_2/pg057-fifo-generator.pdf ?
Read carefully chapters 5 and 6. They show you how to use the FIFO in a testbench.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
miti
@alfamanager ,
