Scholar dwisehart
Vivado 2013.3 simulation duplicates signals and then won't let you delete them
In the simulator waveform window, if you select two signals at once and drag them to a different location in the list of signals, one of them will be duplicated.
If you then try to delete the three signals that are showing, only two of them will be deleted and the third one will refuse to be delete even on subsequent attempts.
This looks like a GUI bug to me.
Daniel
Re: Vivado 2013.3 simulation duplicates signals and then won't let you delete them
Hi Daniel,
I have created a change request 794564 on this issue. It will be fixed in future releases of vivado.
I hope this may help you. Thanks for reporting this incorrect behavior.
Harry
Hi Daniel,
What is the OS you are working on?
I tested this on win-7 machine where it worked fine.
Deepika.
Deepika.
Scholar dwisehart
Linux: RHEL 6
Scholar dwisehart
I just checked and this bug is still in 2014.1.
Daniel
Thanks Daniel.
I am able to reproduce the issue in 2014.1
here is the snapshot
I will file a change request on this issue & let you know the change request number.
Harry
Hi Daniel,
Harry
