Vivado 2015.1 Simulator does not launch
Recently I've installed Vivado tool after downloading from xilinx website. Whenever I want to run the "Run Behavioral Simulation" after creating a testbench, messages is displayed as below but the simulator doesn't launch. I am net to this tool and have already invested 5 days for resolving this problem. Kindly help!
in log window I get the following
INFO: Scripts generated successfully. Please see the 'Tcl Console' window for details.
in tcl window I get the following:
INFO: [USF-XSim-27] Simulation object is 'sim_1'
INFO: [USF-XSim-37] Inspecting design source files for 'test_mux1_vhdl' in fileset 'sim_1'...
INFO: [USF-XSim-97] Finding global include files...
INFO: [USF-XSim-98] Fetching design files from 'sim_1'...
INFO: [USF-XSim-2] XSim::Compile design
INFO: [USF-XSim-60] Script generated:H:/MyProjects/FPGA/Zedboard/ECE726/Lab_1/Lab_1.sim/sim_1/behav/compile.bat
INFO: [USF-XSim-3] XSim::Elaborate design
INFO: [USF-XSim-60] Script generated:H:/MyProjects/FPGA/Zedboard/ECE726/Lab_1/Lab_1.sim/sim_1/behav/elaborate.bat
INFO: [USF-XSim-4] XSim::Simulate design
INFO: [USF-XSim-60] Script generated:H:/MyProjects/FPGA/Zedboard/ECE726/Lab_1/Lab_1.sim/sim_1/behav/simulate.bat
However, I am unable to see the waveform window i.e. simulator
Hi @rrsingh70,
This selection is completely dependent upon the features and tools which you wish to install additionally with Vivado Design Suite. If you check, there is a description of each of this edition at the bottom of their name in the installer. You can check the features and decide based upon your requirements.
You can also take help of 'Edition Selection' topic from below UG
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_1/ug973-vivado-release-notes-install-license.pdf
Ashish
Hello @rrsingh70,
Go to Flow Navigator -> Simulation Settings -> Uncheck "Generate scripts only"
Ashish
Hi Ashishhd,
Thanks!
Trided it but getting fata error. Screenshot is attached.
I've tried several options available on user forum then posting this.
Hello @rrsingh70,
Have you checked Tcl console as mentioned in error? Can you now share the output at Tcl console?
Ashish
Yeah Ashishhd!
Getting the same message as in the pop-up window attached earlier.
Hello @rrsingh70,
Can you share your design so that we can have a look at the issue and we can suggest some workaround.
Ashish
Sure!
Attached!
I am a newbie. Hope you understand!
Hello @rrsingh70,
The issue is not reproducible at my end. I am able to launch simulator successfully. You can try below options and let us know if they helps -
1. Clear <project_name.sim> directory and try simulating the design again.
2. Build the project from scratch at some other location and then try simulating the design.
Ashish
I'll try ASAP. Did my code run successfully?
Hello @rrsingh70,
Yes, I am able to simulate your code and launch the waveform window.
Ashish
Could it be an installation prob. However during installation I'd disabled antivirus etc. as suggested on user forums....
Hello @rrsingh70,
Before suspecting an issue with installation, I would recommend to try the options mentioned in my earlier post. Also try simulating an example design provided with Vivado Design Suite.
If all these options are resulting in failure, you can suspect it to be an installation problem and re-install the tool.
Before uninstalling, please make sure that you return all the activation based licenses to Xilinx Product Licensing site so that you won't be in trouble later.
Ashish
I tried in a new location from scratch. Not resolved, almost same kind of problem I am getting. Please see the screen shot. Thanks!
Triedn running an example project too. Same problem persists. That means I am left only with the last option i.e. reinstallation.
Hello @rrsingh70,
Make sure that you are using supported operating system as specified in below UG (page #15)
You can also refer below thread as a reference
http://forums.xilinx.com/t5/Simulation-and-Verification/XSIM-43-3915-Error/td-p/533989
Ashish
I am using Windows 7, 64-bit which is supported by Vivado.
Hello @rrsingh70,
Are you able to simulate the design successfully after checking the thread mentioned in earlier post?
Ashish
No Ashish, I was just trying to send the license to xilinx. When I clicked the License Manager and clicked Return License to xilinx, I got nothing in the list. Whereas when I used view license status option I am getting some license installed I've just received another license for vivado WebPACK which could be seen in the attachement. Is it the right license file? When I am using return option now only the new one is displayed. What to do now?
Hello @rrsingh70,
You need not to worry about licenses in the top portion of your snapshot which are certificate based. But you need to return licenses which are present in bottom portion (Activation based). Now you need to select 'Return License to Xilinx', then you will find one license there. Return this license and then continue with your process.
Ashish
Dear Ashish, I've Started Installation. Which option should I select?
- Vivado WebPACK
- Vivado Design Edition
- Vivado System Edition
Hi @rrsingh70,
Ashish
Dear Ashish,
Successfully launched the simulator after new installation.
Thanks a lot!
Dear Ashish,
I ran many programs when the simulator launched after reinstalling Vivado (discussed earlier).
Since Friday, I am not able to launch the simulator again. It gives me the error pop-up attached that simulator license is not found check License Manager. When I launvh License Manager the license is shown proper.
I've attached two scree-shots.
Kindly Reply
From the snapshot I see that your Vivado webpack license is expired.
Vivado_HLS license will not include Vivado simulator license feature.
Hello @rrsingh70,
It is always recommended to open separate thread for fresh query.
Can you open new thread and attach your license file along with output of below command in Vivado Tcl console -
report_environment -file <directory_name>/xinfo.txt
Ashish
Dear Manusha,
Does "Permanent" mean expired? Under the Vivado_WebPACK its listed as "Permanent".
Sure,
Doing
Thanks Ashish
No, permanent means you can use all Vivado versions permanently which were released before version limit(for your license it is 2016.07)
Check this AR for details on version limit.
http://www.xilinx.com/support/answers/33770.html
You should be able to use vivado simulator in 2015.1 with this license
Can you run below command in Vivado console and share the output here?
report_environment -file <directory>/xinfo.txt
