Vivado 2015.3 XSIM testplusarg
If I run the following command with batch file(simulate.bat) , completes with error.
But I run the command in Xsim(TCL Script), completes with no error.
In batch file case, Xsim does not recognize the option "-testplusarg".
The other is ok.
====  Command ======
xsim board_behav -key {Behavioral:sim_1:Functional:board} -gui -wdb board_behav.wdb -view board_behav.wcfg -log simulate.log -testplusarg TESTNAME=BMD_Rd_DMA
Re: Vivado 2015.3 XSIM testplusarg
@linuxbios
Use the option as -testplusarg "TESTNAME=BMD_Rd_DMA" in your testcase. That should work.
Debraj
Hi @linuxbios,
If you are using windows, make sure you call the xsim executable:
Refer to this AR for details: http://www.xilinx.com/support/answers/63986.html
Let me know if this helps.
Nupur
Nupur
Are you seeing an error as -testplusarg is not defined or the error is that the testplusarg are not applied to your verilog code?
Also, in simulate.bat, you would see the entry as:
set xv_path=C:\\Xilinx\\Vivado\\2015.2\\bin
call %xv_path%/xsim Testbench_behav -key {Behavioral:sim_1:Functional:Testbench} -tclbatch Testbench.tcl -log simulate.log
Are you running the same command in TCL also?
Debraj
I attached the result after running "simulate.bat"
=== Command =====
Hi @linuxbios
I tested plusargs at my end with a simple code:
module valuetest();
integer i;
initial
begin
if($value$plusargs("INTG=%d",i))
$display(" GOT INTEGER ");
$display(" Integer is %d ",i);
end
endmodule
And in xsim used: -testplusarg INTG=123
Output:
GOT INTEGER
Integer is 123
Can you please cross check your usage?
Thanks,Vijay
I attached the file what I did as you said.
I failed with the same error.
Hi @linuxbios
Iam attaching the scripts with which Iam able to run the design for your reference.
Thanks,Vijay
Use it as -testplusarg "TESTNAME=BMD_Rd_DMA" in Command Prompt of Windows and not -testplusarg TESTNAME=BMD_Rd_DMA. The " " are missing for the argument list.
Debraj
I tested your zip file.
The result is fail with the same error.
@linuxbios
Debraj
Thanks your reply.
"tcl script" works either ways.
"batch file" works only one way("TESTNAME=BMD_Rd_DMA").
That are my result.
But, Any user guides do not use of ("TESTNAME=BMD_Rd_DMA") way.
