Vivado 2017.3 does not show missing module/s message
In Vivado how do we find out if a file related to an instantiated module has been added to the project or not?
This is because simulation proceeds without showing any messages in the TCL console.
I know if I browse inside the Sources window expanding the project hierarchy, then I will find it. But for a large project this is a painful work.
Is there any TCL command or something to find out if a file needs to be added to the project which is already instantiated?
FPGA enthusiast!
All PMs will be ignored
Re: Vivado 2017.3 does not show missing module/s message
Hi @dpaul24,
Can you check by clicking on question mark which is shown in source window? By clicking, it will only show missing sources.
hemangd
hemangd
Hi @dpaul24,
hemangd
hemangd
@hemangd,
ok I get it now.
One has to click on the "?" 'Show only missing sources'
FPGA enthusiast!
