naeim35
Vivado 2017.4 Modelsim verification License issue
Hi all,
I try to use ModelSim PE Simulator instead of the default Vivado Simulator. I have created a TestBench which includes the AXI VIPs blocks using Vivado 2017.4 . When I run the simulation including the DUT the ModelSim simulator runs but I encounter with this Error:
# Loading xilinx_vip.axi_vip_if_sv_unit
# Loading xilinx_vip.axi_vip_axi4pc
# Loading work.gash_axi_vip_1_0
# ** Error: (vsim-1) Unable to checkout verification license - testbench generation feature (randomize, randcase, randsequence, covergroup) is only supported with QuestaSim.
#    Time: 0 ps  Iteration: 0  Instance: /gash_tb File: ../../../../gash_tb.srcs/sources_1/new/gash_tb.sv
# Error loading design
# Error: Error loading design
#        Pausing macro execution
# MACRO ./gash_tb_simulate.do PAUSED at line 9
My question is that if ModelSim PE 10.5a supports AXI VIPs? Is there any solution for this problem?
Best regards,
Naeim
amaccre
HI @naeim35,
You need to use ModeSim 10.6b or later with Vivado 2017.4.
This is documented in User Guide 973
Vivado is very specific about which versions or third party tools are supported as there are frequent additions and updates of IP.
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
