tschesnok
Vivado 2020: Simulation (behavioral) can't find .v file... corrupts file name every 4-5 times I restart Sim.
Use case:
I have a verilog module and a corresponding TB module.. in the same file.
I make the TB the top level. Click on Simulation (behavioral) and it starts up and I get my waveforms.
I then make an edit to the file.. save via the file save icon.. and hit reload on the simulation... works most times..
But every 4-5 times I get an error when restarting the sim: "can't find file" pointing to my verilog file but with the path repeated twice: i.e. "path/filename.v/path/filename.v" which of course it can't find.
Only way to solve the problem seems to be to delete the .sim directory.. then all works again.. till the next time.
Am I the only one.. or is this common? Is there an easy fix?
ansarimo
Hi @tschesnok
Which Vivado version are you referring to 2020.1 or 2020.2?
I created a simple test-case with both DUT and TB in the same file in 2020.2 and wasn't able to reproduce the issue you mentioned, I  suspect this how your hierarchy looks like as shown in the snap below:
I even edited it multiple times but unfortunately wasn't able to reproduce it, if possible then share your test-case with all the steps to reproduce the issue.
Also, on which OS Vivado is installed?
Thanks and Regards,
Ansari Hunen
Don’t forget to reply, kudo, and accept as a solution.
tschesnok
Running 2020.2 (64bit) on Ubuntu 18.04.1 LTS with 32 GB ram/6 cores/12 threads.
I have now been on at least a 20 edit run without problems.. so perhaps it is resolved? I can live with it since the remedy is very simple (delete the folder).
I wish I could help further since this really seems like a bug/edge case. I will circle back if I figure out more or if it happens again. In my mind I imagined it to be a timing issue.. where I clicked "rerun" on the simulator before everything updated after saving the file.. I have been going slower now.
ansarimo
Hi @tschesnok
Good to know you managed to pass this issue.
Please close this thread by accepting it as a solution so that it can help other users too.
Thanks and Regards,
Ansari Hunen
