Vivado VHDL simulator (2017.3) does not correctly handle "process(all)" sensitivity list.
Vivado (2017.3) VHDL simulator (file set to 2008 mode) does not handle "process(all)" sensitivity list where the sensed signal is a a slice from inside a record.
- XILINX, can you confirm this?
- XILINX, when can I expect it to be fixed?
- XILINX, do you not have extensive test cases (other than the community doing it on behalf on you) to find these kinds of misses?
On below, the signal d(10) should change at 1 µs and 2 µs. But it does not.
    process(all)
    begin
        d(10) <= s_rec.a(1); -- This does not work in Vivado 2017.3 simulator !!!! Works with Aldec.
    end process;
Br, -Topi
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity test_process is
end;
architecture Behavioral of test_process is
    type rec is record
        a: std_logic_vector(15 downto 0);
        b: std_logic;
    end record;
    signal s_rec: rec;
    signal a: std_logic;
    signal b: std_logic;
    signal d: std_logic_vector(150 downto 0);
    signal x: std_logic_vector(15 downto 0);
    signal y: std_logic_vector(150 downto 0);
begin
    process(all)
    begin
        a <= s_rec.a(10);
    end process;
    process(all)
    begin
    end process;
    process(all)
    begin
        y(3) <= x(15); -- This works ok.
    end process;
    process(all)
    begin
        b <= s_rec.b; -- This works ok.
    end process;
    process
    begin
        wait for 1.5 us;
        x <= (others => '1');
        wait;
    end process;
    process
    begin
        wait for 1 us;
        s_rec.a <= (others => '1');
        wait for 1 us;
        s_rec.a <= (others => '0');
        s_rec.b <= '1';
        wait;
    end process;
end;
Re: Vivado VHDL simulator (2017.3) does not correctly handle "process(all)" sensitivity list.
HI @topi-procemex,
Thanks for the sample code, I tried running it in Vivado Simulator from 2017.3, 2018.1 and in ModelSim 10.6c.
In ModelSim, you can see that there is a transition of the data shown after 1us, but the value on the bus has not changed.
In Vivado 2017.3 this transition is not shown as the values have not changed.
Likewise for 2018.1
What are you trying to see that you believe is incorrect?
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
Aidan,
This is the result from Aldec Active-HDL. I do not have Mentor so I cannot test with it.
You should notice that the bus d shows a transition like event at 1 µs, but looking at d(10), you notice it is actually a change of value rather than a mere glitch.
From your Mentor screenshot I cannot say wether Mentor is doing it the right way, or failing it.
Br, -Topi
Hi @topi-procemex,
Thanks for the clarification, I can see the difference in behaviour now.
ModelSim has the same behaviour as your Aldec output and Vivado Xsim is not showing the expected change on d(10).
I will check if this has been reported previously and if not I will create a Change Request to get this issue fixed.
I will post back here with an update either way once I receive a response
Best Regards
Aidan
P.S. If you include the @ version of the persons name in your reply then they get notified.
It may help if you need a quick response in the future.
Hi @topi-procemex,
I have created a Change Request to get this issue fixed.
Best Regards
Aidan
Not yet fixed in 2019.1
