Vivado can't find Questasim
Hello all,
I can't find a solution to this. I've set all the paths in the GUI for Vivado to find Questasim. I'm sure its there, I can source the QuestaSim environment and call Vsim. I can even launch a simulation from Vivado for a simple adder, but I can't get the simulation libraries to compile.
Here's the tcl call that vivado generates:
compile_simlib -simulator questa -simulator_exec_path {/media/me/HDD/QUESTA-CORE-PRIME_10.5c-4/questasim/bin} -family virtex7 -family virtexuplus -family zynquplus -language all -library all -dir {/media/me/HDD/QUESTA-CORE-PRIME_10.5c-4}
And the resulting error:
ERROR: [Vivado 12-3754] Failed to find the 'questasim' simulator executable. Make sure to set the 'questasim' installation environment and retry this command to compile the libraries for this simulator. For more information on tool setup refer 'questasim' user guide
I've tried other directories as well, such as:
/media/me/HDD/QUESTA-CORE-PRIME_10.5c-4/questasim/linux_x86_64
I get the same results. Any ideas?
Re: Vivado can't find Questasim
Hi @bandit,
You can try " which vsim "command in terminal to get the path of vsim executables and point that path in the compile_simlib command.
I'd done that, it was one of the paths I tried.
HI @bandit,
Can you once please try setting the environment variable in terminal an invoke vivado for compiling simulation libraries from the same terminal itself?
setenv PATH /media/me/HDD/QUESTA-CORE-PRIME_10.5c-4/questasim/linux_x86_64/:${PATH}
