Vivado synthesis timing simulation
Hello.
There are some things I don't understand about synthesis timing simulation in vivado.
When you do synthesis timing simulation in vivado, how do you measure the time from where to where?
For example, does it include input/output delays, or does it include component delays?
I'd be happy to know.
Hi @imo,
Post-Synthesis timing simulation uses the estimated timing delay from the device models and does not include interconnect delay.
Post-Implementation timing simulation uses actual timing delays.
R.Samhoud
Don't forget to reply, give Kudo and accept as solution
Hi @imo ,
Please refer to UG900:https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug900-vivado-logic-simulation.pdf page 67 for a detailed description of running simulation.
Please let me know if you still need more assistance.
R.Samhoud
Thanks for the answer.
I have one question after browsing the site.
The TIP on page 68 says that the interconnect delay is not included in the TIP. However, on the same page Post-Synthesis Timing Simulation says that estimated values for component delay are available. I am aware that interconnect delay is included in component delay in a larger sense.
Is interconnect delay included in Post-Synthesis Timing Simulation?
Thank you for your help.
Hi @imo,
R.Samhoud
Thank you.
Thanks to you, I was able to understand it.
