a8814
Waveform Viewer redocks when relaunching
Is there a way to prevent the Waveform Viewer from re-docking itself when a simulation is relaunched? I run a simulation and undock and move the viewer to a separate monitor. If I relaunch I need to do it again. And again. Etc.
Thanks!
gszakacs
Instructor
Instructor
First, what version of ISIM are you using?
What Operating system?
32 or 64 bit version of ISIM?
When I do this, I have found that using the Re-Launch button in the Wave Viewer window does not give me this behavior, while using the Re-Launch button on the main ISIM window does.
I'm currently using Windows XP Pro 32-bit and ISIM from ISE 14.7
-- Gabor
yashp
Please refer this AR: http://www.xilinx.com/support/answers/34549.htm
Yash
a8814
Wow! Rookie mistake not including my system info! Sorry!
Vivado 2014.2
Windows 7 64-bit
I don't see a relaunch button on the waveform window and the referenced AR is for ISIM (I don't see the same options).
