Why Vivado 20l5.1 simulation always stuck on Ubuntu 14.04?
Hi everyone,
We are trying to run RTL behavioral simulations using Vivado 2015.1 on Ubuntu. But why does it alway stuck? we have already clicked the bottom F3 (Run All) but the simulation still stuck every 5 min or so. As a result, we have to click around the GUI of Vivado such as a Zoon-in bottom to "wake" the simulation so that it can continue running.
Why and How to solve it?
Really appreciated,
Hi @pligroup,
I am not sure why the simulator is behaving such, but can you have a look if this AR helps in your case?
http://www.xilinx.com/support/answers/59599.html
Nupur
Accept as solution if it resolved your query, give kudos(click on star) if it led you to the solution.
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the 'thumbs-up' button).
Hi @pligroup
I remember similar issue reported before with other OS. Can you please try using the latest version of Vivado 2015.3.
If you still see the same issue, please attach the design here for us to look into.
Thanks,Vijay
@pligroup
Are you seeing the same behavior with Xilinx example designs also? Can you check and let us know if this is machine specific issue.
Anusheel
Search for documents/answer records related to your device and tool before posting query on forums.
Search related forums and make sure your query is not repeated.
Please mark the post as an answer "Accept as solution" in case it helps to resolve your query.
Helpful answer -> Give Kudos
Thanks for your reply.
Actually, our RTL design is huge but our machine which runs the simulation has only 4GB RAM.
Is there a problem with the small RAM?
Thanks again
Hi @pligroup
Please check the memory requirements based on the device that you are tageting.
http://www.xilinx.com/design-tools/vivado/memory.htm
Memory plays a significant role in the performance of the tool.
Thanks,Vijay
Hi @pligroup
Did that helped? Close the thread by marking the solution.
Thanks,Vijay
